Is there a fuse for the map lights?
Old Dec 27, 2011 | 09:02 PM
D Grade's Avatar
Upon installing LED bulbs in the map lights, door open light (between the map lights), and dome light, the map lights no longer work. Door open light still works as well as the dome light, but not the two map lights. Checked the fuse (fuse 18) but that is for the dome light. I also tried flipping the led bulbs as well as putting the stock non LED bulbs back in, they still don't work.
Anyone know of the fuse location or another possible issue?
Old Dec 27, 2011 | 09:48 PM
eponti's Avatar
its located in the engine bays fuse box.Location # 22 & 23 they are both attached together with a yellow tab.
Old Dec 28, 2011 | 10:53 AM
D Grade's Avatar
You are a god, thank you! I assume they are standard fuses?
EDIT: Found out they are mini 10A fuses for future references. Thanks again, eponti!
Old Dec 28, 2011 | 02:06 PM
eponti's Avatar
yup standard 10 amp fuse.
Old Dec 28, 2011 | 02:16 PM
Ryan.Kauz's Avatar
LED bulbs.... You are such a Baller Derrick.
Old Dec 28, 2011 | 02:25 PM
D Grade's Avatar
Baller =Ricer, I know Ryan.
Old Jan 12, 2012 | 05:53 AM
crak's Avatar
what size bulbs are in the dome and map lights?
TxFAkuma
Jul 20, 2016 02:02 PM
HideouStrength
19
Dec 2, 2014 11:26 AM
jnsport12
Mar 20, 2014 07:38 PM
pinoy6969
Northwest Region
Aug 29, 2011 09:53 PM
impreza2darksyd
Jul 13, 2011 02:17 PM
