No heat please help.
As the title suggests I have no heat until the car warms all the way up. I have an after market radiator and and after market thermostat (don't know if that matters much)... last winter I did not have any issues(no mods have changed since then).
The car use to blow hot air within just a few min of running....now it doesn't blow even semi warm air until I let the car run for 10+ min at an idle, then once I start going and the motor cools down I don't get the warm air any more. I don't know much about HVAC systems so please forgive my n00bness. Could this be a bad heater core?
It could be your Coolant level. You should check it. If there isn't a dense conductive fluid to transfer thermal energy into the heater core it won't get hot. Also if there isn't a dense conductive fluid flowing around your cylinders to absorb thermal energy they won't be cooled and if there isn't a dense conductive fluid flowing through you radiator it won't absorb the thermal energy from the engine and dissipate it. So yeah your coolant is important and you should check it often.
The thermostat and radiator have been in for a little over a year now. I don't ever remember not having heating issues. If I can find my stock thermostat I will swap them out and check. If that's what the issue is then It's not a huge deal, I will just have to save for a daily drive
1 Post
I've had this issue with my car since I had motor swapped. I have to put it on defrost in order to get heat and when I have it on any other setting its cold air regardless of the temp of the motor
Is your blend door moving freely? They gum up on the '03s due to a lack of cabin filter and can stick, despite the knob being all the way at heat the door can be halfway between. check to make sure the lever arm in the driver's footwell is moving as it should when the knob is turned.
Otherwise, you might have an air bubble trapped in the heater core. Try burping the system to see if that helps.
You have the honor of being the forth person this fall who has posted with this problem, that is, aftermarket thermostat and no heat. In two cases the OEM thermostat fixed the problem. Never heard back from the third people but he had a Mitsu thermostat on order.
My heat did work last winter. I checked to see when I had ordered the thermostat/radiator and it has been over 2 years. I am going to check the blender door like another person had suggested.
