Thumping sound when shift, help!
Old Jan 3, 2012 | 06:07 PM
lanberg's Avatar
I test drove an evo I have been looking to buy and when I got on it there was a thumping sound when I shifted gears, I asked the owner what the noise was and he said it was normal. He said it was because it's all wheel drive and the power goes directly to the wheels.It isn't a real loud thump but definitely noticeable.
can anyone give me info?
Old Jan 3, 2012 | 06:09 PM
hiner005's Avatar
There are plenty of evos around. Take your time and try to find one with no issues.
silver9mr's Avatar
where you shifiting it kind of hard? if so then yes this is normal. there is a lot of drive tran so when its shifted hard its just all the power making its way to the wheels.
Old Jan 3, 2012 | 06:12 PM
lanberg's Avatar
this evo is perfect except for that. its even bone stock. so you werent help.
Old Jan 3, 2012 | 06:14 PM
lanberg's Avatar
perfect answer, thanks alot man <3. now im not worried
Old Jan 3, 2012 | 06:16 PM
llDemonll's Avatar
if it's coming from the rear end under a hard, high rpm shift (wot, fast shifting) that's the rear diff and is a normal noise (can be eliminated with new mounts and a moustache bar)
if it's coming from somewhere else that's not normal
Old Jan 3, 2012 | 06:20 PM
badev0's Avatar
Demon is right, if you're shifting fast & letting the clutch out fast and you are hearing that clunking sound, its most likely coming from the rear end which can be eliminated with the mods mentioned above.
Old Jan 3, 2012 | 06:23 PM
wizzo 8's Avatar
Normal. You can replace the rear diff bushings to eliminate it.
Old Jan 3, 2012 | 06:27 PM
dmcghie's Avatar
its pretty much normal...dont forget ur driving an awd that makes plenty of torque, think of it this way....if u were driving a fwd car with the same power you would get wheel spin when hard shifting in the lower gears
5speedwtneed's Avatar
Mine doesn't clunk... But I have upgraded bushings everywhere.
Old Jan 3, 2012 | 06:42 PM
JTEVO2932's Avatar
yup rear end....go buy it
Old Jan 3, 2012 | 06:57 PM
rocknsnoboarder's Avatar
As long as it's the rear you're good. The diff hits pretty hard when you get on it.
Old Jan 4, 2012 | 01:11 AM
Playap07's Avatar
Veteran: Air Force
dont drop the clutch under wot. If thats what you were doing and it made that noise it was the driveshaft/diff hitting the top of your chass. It happened to me when i first got my Evo. I learned never to drop the clutch on WOT anymore!
Old Jan 4, 2012 | 04:10 PM
redhead714's Avatar
This thumping sound you hear, can you feel it in the shifter too? I just bought an Evo last week and when I am doing quick shifts I can feel it kinda clunk into gear but under low rpm slow shifts I don't feel/hear it any more. Same thing you guys are talking about or should I be worried?
Old Jan 5, 2012 | 02:41 PM
Atrophical's Avatar
I agree and did that myself. Everything's fine now.
supak1111
Nov 30, 2016 07:17 PM
RiioT
24
Sep 30, 2016 02:17 PM
idiaroi
Aug 27, 2015 09:02 PM
scherejs
19
May 2, 2010 05:40 PM
MyEv08u
32
Mar 19, 2009 05:56 PM
