What RPM should I see boost?
Old Jan 24, 2012 | 03:46 PM
Mrauto50's Avatar
I'm just wondering if this is normal.
I see boost around 3200rpm. Is this late? My mods are as follows.
MAP 2.3 stroker (Stage2 upgraded)
Stage 3 Head
GSC S1 cams
Jacks stage 3 Trans (Evo9 1st)
Shepard transfer case
255 fuel pump
FIC 1250's
FIC fuel rail
EcuFlash
ACT HD
Perrin Exhaust
Perrin Filter
Greddy BOV
Stock Turbo lightly ported & polished stock wheel & shaft
Injen upper IC and intercooler pipe
running E85
Old Jan 24, 2012 | 03:50 PM
taylorgang's Avatar
It really depends on what gear you're in... a 2.3 stroker would probably see boost faster than the stock 2.0
Old Jan 24, 2012 | 03:57 PM
CurseDSM's Avatar
Also depends on the turbo. 3200 and your at how much boost?
Old Jan 24, 2012 | 04:03 PM
Mrauto50's Avatar
In 2nd gear. I'm at 25lbs. I'm thinking its to late. I'm going to check the spring on the actuator. i think thats what its called...lol
Old Jan 24, 2012 | 04:16 PM
turbotalawd's Avatar
For a 2.3l and all that work plus a stock turbo, that is way too late to be hitting boost. I assume you mean hitting full boost? I would start by redoing the tune.
Old Jan 24, 2012 | 04:22 PM
MechTech's Avatar
Originally Posted by turbotalawd
for a 2.3l and all that work plus a stock turbo, that is way too late to be hitting boost. I assume you mean hitting full boost? I would start by redoing the tune.
+1
Old Jan 24, 2012 | 08:33 PM
Mrauto50's Avatar
Retune it is ..Thanks guys!!!
aquaMan219
For Sale - Cars For Sale
Oct 5, 2015 06:16 AM
VerbalKilla
Nov 28, 2014 02:33 PM
Brianawd
Oct 25, 2012 04:30 PM
ReignMan24
Oct 12, 2012 11:01 AM
3dman1
May 3, 2009 12:13 PM
