Not sure what cams are in my car?
Old Feb 17, 2012 | 08:38 AM
BooHAHA's Avatar
I bought my Evo 9 used it came with some aftermarket parts. Most of the stuff is pretty easy to spot, but I am not sure if the cams are stock or aftermarket. My vacuum at idle is between -12 and -14. I removed the oil cap and took a picture. Thanks for any help.
Old Feb 17, 2012 | 08:41 AM
PearceEVOix's Avatar
Was JUST about to ask this same question haha
Old Feb 17, 2012 | 08:42 AM
rayman0690's Avatar
You normally have to remove them and look at the end of the stick itself. They will have some kind of marking or logo that should indicate the type
Old Feb 17, 2012 | 12:12 PM
BooHAHA's Avatar
stock cams after warmed up at idle should be around -20 right?
Old Feb 17, 2012 | 12:57 PM
HaVoC187's Avatar
Yes my car pulls -18 to -20 vacuum at idle.
Old Feb 17, 2012 | 01:01 PM
evo8426's Avatar
If you are able to pull your tune chances are we can tell you if they are stock or not
Old Feb 17, 2012 | 01:06 PM
EvoJoeIX's Avatar
If your only at -12 vac they aremt stock cams....
To find out what they are, you will have to at least pull the valve cover, of not take one of the cams out
Old Feb 17, 2012 | 01:26 PM
BooHAHA's Avatar
I guess I will have to pull the valve cover to find out for sure.
Old Feb 17, 2012 | 01:29 PM
4RETECH's Avatar
Yes, then you can see the color code and engravings on the cam.
Old Feb 17, 2012 | 07:46 PM
evo8426's Avatar
His gauge could be inaccurate
Old Feb 17, 2012 | 07:57 PM
EvoJoeIX's Avatar
Thats true, im assuming his gauge is correct though....which could backfire
Old Feb 17, 2012 | 08:15 PM
marcusE's Avatar
I pull well over 20 vac at idle on stock 8 cams..
My buddy with 272 hks pulls around 13-16 at idle.
Old Feb 17, 2012 | 08:25 PM
RocketDive's Avatar
As long as your gauge is accurate, I'm agreeing with the stock cams. But a little time in the driveway is well worth the peace of mind to me. Good luck!
Old Feb 17, 2012 | 10:21 PM
cmspaz's Avatar
I pull 16-19 on HKS 272s.
Old Feb 18, 2012 | 06:11 AM
BooHAHA's Avatar
on a evo 9 what is the cold start idle at?
