Fuel pump relays?
Old Mar 3, 2012 | 03:48 PM
jdr7919's Avatar
Fuel pump relays?
Im trying to find out where all the fuel relays are. My pump is not turning on I can hear one relay click under the dash when I turn it on thru evoscan. Where are the other 2? I read they are on the fire wall on the driver side but I dont see anything there. Just 2 on the passenger side fire wall.
This is on a evo 9
Thanks
Old Mar 3, 2012 | 07:12 PM
jdr7919's Avatar
Anyone?
Old Mar 4, 2012 | 10:09 AM
jdr7919's Avatar
please help a guy out
Old Mar 4, 2012 | 05:36 PM
jdr7919's Avatar
? help
Old Mar 5, 2012 | 06:37 AM
fwd_josh's Avatar
when you look at the fuse box under the dash there are 3 relays vertically along the left side. the top and bottom relays are the fuel pump relays. I have the diagram at home, i'll try to scan it and post it later.
Old Mar 5, 2012 | 08:31 AM
tweaker41's Avatar
The ones under the hood are mounted on the passenger side firewall onto a metal plate that's bolted to the firewall. If you need a service manual go to the evoscan website.
Old Mar 5, 2012 | 09:39 AM
jdr7919's Avatar
Thanks! and a diagram would be great!!!!!!
Old Mar 11, 2012 | 06:29 PM
jdr7919's Avatar
Just had a chance to work on the car again.
I tested all 3 fuel relays and they are good no blown fuses. Fuel pump is not getting power.
I have power at both fuse boxes but I don't think I'm getting power to the relay on the
fire wall. Where do I go from here?
Thanks
Old Mar 11, 2012 | 06:40 PM
Evo8Emperor's Avatar
any easy way to see if they fuel pump has just **** the bed which i have no idea of your driving styles, habits, miles per day, etc to really know if it was actually a reasonable guess.
but just run a jumper wire from the battery to the fuel pump under the rear seat.
Old Mar 12, 2012 | 09:25 AM
jdr7919's Avatar
Fuel pump is new. I even put the stock one back in to see if it would work and still wont start.
Old Mar 12, 2012 | 09:33 AM
RallySport9's Avatar
Does your engine oil smell like gasoline by any chance? I had the same problem, thought it was the fuel pump or it's relays short to ground..it was really an injector stuck open and for some reason it caused the pump not to activate like normal..just a thought.
Old Mar 12, 2012 | 05:26 PM
jdr7919's Avatar
I will check that thanks.
Anyone else have any thoughts?
Lightsaber
Apr 4, 2018 10:02 AM
bryonboals
Mar 13, 2017 10:05 AM
Mike W
84
Aug 19, 2016 08:36 AM
STIU2SLO
Jun 19, 2016 07:40 PM
walker992
Oct 19, 2012 08:26 AM
