Cylinder 4 reading low
Old Mar 5, 2012 | 06:52 PM
MaDD-Myke's Avatar
MY EVO 8 IS NOT A 100% WHERE IT SHUD BE RIGHT NOW,CYCLINDER 4 IS READING A LOW 85 WHILE THE OTHER 3 IS AT 160..WHATS A SIMPLE FIX FOR THIS AND HOW MUCH WUD IT BE?
Old Mar 5, 2012 | 07:49 PM
JDMwannabe's Avatar
Any other information? Was the engine warm? Did you put a few drops of oil in the cylinder?
Old Mar 6, 2012 | 04:14 AM
xxthayxx's Avatar
Do a leakdown test that will point you in the right direction. depending where compression is leaking it could be an issue in the head or bottom end.
Old Mar 6, 2012 | 07:42 PM
MaDD-Myke's Avatar
yes...thats not a bad idea...i will have to check that out
Old Mar 7, 2012 | 05:50 AM
Pssst's Avatar
But agreed on the leak down test. I have a similar problem b ut mine is cyl 2 and 3
GL
Old Mar 7, 2012 | 06:44 AM
barneyb's Avatar
You most likely have a ring problem in one cylinder.
Old Mar 7, 2012 | 06:52 AM
STIKiller4G63's Avatar
Yep, I agree...you will have to get it honed and do oversize rings below you lose complete compression...stay out of boost
ridenrunwv
Sep 17, 2015 01:17 PM
QuickIX
18
Jun 22, 2015 07:08 AM
gSx
Jul 19, 2014 10:50 AM
ithveno339jfkj4kjekjqqqq
Mar 1, 2012 06:25 AM
chewyobaca
27
Mar 15, 2010 04:26 PM
