PCV Valve on valve cover popped off
Is that bad? what does it mean? it's the PCV valve that is located on the back side of the cam shaft cover near the Oil cap on my 8. It popped out, and a little oil came out too. I just put it back in for now, should it pop in? snap in? or what? and it sounds like there is a loose spring in the valve is that normal?
Thanks guys!
Stilllllll learrnnning/
Thanks guys!
well it does shake back and forth and it just goes in, loosely?
and which is the right direction?
what would cause the valve cover to build pressure?
It's a friction fitted part,so just make sure it's tight in there and that it's working right,it's supposed to point to the timing belt side of the engine,crankcase pressure is a normal occurrence inside any engine,specially turbocharged ones,the engine has the pcv system in place to expel the blow by gasses out of the engine thereby preventing the build up of gases,the only thing that would prevent the pcv system from working would be a bad pcv valve (stuck closed or clogged) or a closed or clogged intake breather hose,or the engine might be generating extra blow by gases due to bad or worn out piston rings.
