AFR Bounce 13-18+(lean) non stop while idling and cruising.
Started today after work. Recently (week ago) i installed a vacuum block, and everything to my knowledge is hooked up correctly. Been driving for about a week, but today after work afr gauge started going weirdo.
During Idle or while Cruising, it'll bounce from 13'ish to full lean 18+. Car drives fine, and wot afr's are still good.
If this helps at all, i was outside few mins ago, let the car warm up, just idle, and after a few minutes the afr's held steady at 15.3, but as soon as i touch throttle it starts bouncing agian.
Any suggestions?
dave
p.s. look over vacuum hoses and everything seems to be intact.
Any suggestions?
dave
Any suggestions?
dave
Any suggestions?
dave
I had a very small leak develop a couple weeks after installing my Omni 4 bar map sensor that caused similar driveability issues as you're experiencing now. The only way the leak could be detected was during a boost leak test, so I think you should start off with one of those. I would be surprised if you didn't have a small leak somewhere.
I read somewhere that unstable voltage(from battery per-say) could also throw off the afr readings. I check my cables going to the battery in the trunk yesterday, reset the breaker(fuse) and wiggled the power line a little. Not sure if that helped it at all.
Off to do a leak down test.
dave
Did a boost leak test today.
Had a few small bubbles/leaks
-stm egr block off plate
-intake to throttle body gasket (need new)
-few vacuum hoses on fittings (fixed)
-t fitting (fixed)
-turbo housing (ewwww, must fix asap)
As far as the AFR's, they fixed themselves overnight, go figure. Maybe it was me touching the cables that run to the battery in the trunk? Which make no sense but ill let it be.
As far as "Boost Leaks" go, i'd RECOMMEND +999999 for everyone to get one done, its very easy process and it'll do your car good!
dave
-t fitting (fixed)
dave
-t fitting (fixed)
dave
-t fitting (fixed)
dave
Found some good info here
https://www.evolutionm.net/forums/ev...-notice-2.html
Thats exactly where my turbo was leaking pretty bad. Removed it today and slapped a nice little bead (of Permatex Ultra Grey) around the edge and put everything back together. Gonna let it cure for 24 hours and do another boost leak test and let you know how that turns out.
and decided to paint the housing since i had it apart. Hopefully this VHT paint holds up.
dave
dave
Anubis18
Sep 20, 2013 02:39 PM
