Radiator help please...
Old Jun 23, 2012 | 05:50 PM
foxbear2277's Avatar
Arrow Radiator help please...
Hey guys,
One of the last things I need for my build is a radiator...
I was will be needing a 3/4 radiator that will work with a 3586 and tubular manifold...
1. I was wondering if anyone is running a 3/4 rad with a larger manifold/turbo and what thickness the core was used to actually fit without issues..
2.Anyone other than evodan running a 3/4 dual pass radiator? How do you like it if you do? Does the vehicle run cooler with dual pass? Any advisions on this set up?
https://www.evolutionm.net/forums/ev...-finished.html
^^^this set up is pretty much what im looking for in a radiator... but cant seem to order one as it is custom and requires work for fitment, ultimatley my car wont be able get a radiator like this made and fitted... vehicle is not mobile
3. Anyone know if Buschurs' 3/4 radiator fits with bigger turbos/tubular manifolds.. I cant seem to find the info or pics of it installed exept for the vehicle on the website
I will call Buschur on monday to get their input but was also wondering if anyone has the info
I have already contacted CBRD but it looks like in order to be sure to have everything fit perfect my car will have to go to their shop... unfortunately I live in Canada and require the radiator to run... I am not nearly confident in being in charge of radiator core size and dimensions as I am not sure how thick of a core I can or cant go with until I have the turbo/manifold installed... Which is still weeks away
BTW I am NOT looking for a 1/2 radiator...
Any advice and thoughts are greatly apreciated
Thanks in advance
Chris
Old Jun 25, 2012 | 02:35 PM
bump for help
Old Jun 26, 2012 | 07:45 AM
thepoint4life23's Avatar
IF you read the buschur website it says that it can run a bigger turbo as long and your not running a ff kit. will do about the same job as the stock kit if not cool better
Old Jun 26, 2012 | 03:58 PM
Thank you for the help but I just re-read br info on the rad and no where does it say you can run bigger turbos??
How thick is the radiator anyways?? Definently going to have to call Buschur if I ever get a chance when they are at the shop... too busy at work
Old Jul 3, 2012 | 02:57 PM
bump for help please
Old Jul 4, 2012 | 11:33 PM
jrblackSE's Avatar
CBRD 1.25" w/ Any Slim Shrouded Radiator. I would highly recommend. I am currently running a HTA 86 with a ETS Manifold. Half radiator does not cool properly and my Dual Pass Koyo cant fit a Slim Fan because the radiator is like 3" thick. It fits easily with the turbo and manifold and finally fits with the slim fan. Cools great too! Look into it, you won't regret it because I made one mistake that left me with 2 extra radiators lol GL
Old Jul 5, 2012 | 02:56 PM
That was the initial plan but now I will be needing a 3/4 dual pass rad... a full length radiator will not work for my purposes... if no one on here can suggest anything I will be making a custom one down here... only thing is my timeline will be prolonged for my build beacuse of it... oh well...
EvoDan2004
32
Mar 15, 2016 08:32 PM
David Buschur
Oct 3, 2011 03:49 AM
CBRD
31
May 18, 2011 12:35 AM
CBRD
97
May 15, 2011 11:33 AM
Mellon Racing
Feb 28, 2011 01:42 PM
