The first time my Evo has let me down....
Old Jul 30, 2012 | 01:52 PM
fastyouth1313's Avatar
I hope it's an easy fix
Old Jul 30, 2012 | 01:57 PM
RoMeIX's Avatar
It wasn't the tune that changed, it was something else getting progressively worse, like maybe your spark plugs were starting to go bad etc..,
Old Jul 30, 2012 | 02:00 PM
impact blue's Avatar
Did you check your car for any vacuum or boost leaks. I know my car ran like crap once I had the smallest leak and ran rich to a point it kept stalling out and would not go past a certain rpm you may want to check that too.
Old Jul 30, 2012 | 02:07 PM
okevolutionVIII's Avatar
I'm going with bad gas, it won't burn and will foul the plugs. May also check your fuel filter too, I had a problem with my fuel system that did the same thing. It ran fine at first and progressively got worse and wouldn't stay running more than a few seconds.
Old Jul 30, 2012 | 02:27 PM
blknblubkrdude's Avatar
Originally Posted by wjamyers
shoot, I'm dead serious, not trying to be funny.
just throwing some good vibes your way. I hope you figure this out.
They did get fouled, and I replaced them!
Leak free! Speed density isn't affected by air leaks like a MAF car is.
I will probably end up checking the fuel module like you did.
The only thing, is that bad fuel would not magically become good fuel when the engine warms up.
Old Jul 30, 2012 | 02:55 PM
I am just confused. I got it to start with a sniff of starting fluid, but can only keep it going by going on/off throttle as fast as possible. It just pops and backfires...
Still holding 40-43 psi.
Old Jul 30, 2012 | 03:54 PM
nismo05's Avatar
I had an issue similar to this. My MAP sensor took a ****. I too am on speed density and that's what it was for me. If you were on MAF, then this would be your MAF crapping out.
Old Jul 30, 2012 | 04:09 PM
Good idea!
Were you on OEM MAP?
I am using Omnipower 4 Bar.
Old Jul 30, 2012 | 05:39 PM
boostedrb's Avatar
Any solutions yet?
Old Jul 30, 2012 | 06:09 PM
TheBoz's Avatar
If you have an AIT sensor check to make sure it is reading correctly, and make sure that it is not unpluged.
I had an AIT sensor fail on me, and caused my car to run a default Air Temp(AEM EMS).
You WB, or Narrowband O2 sensor might be going out.
Old Jul 30, 2012 | 06:34 PM
My car is running off fuel temp, so there's no IAT.
I wisg I had ordered a spare 02 when I got my current one so I could check it quickly.
I did however forget to mention that my fuel pump does not prime when turning the ignition to on.
It does when cranking or running, though.
Old Jul 30, 2012 | 06:44 PM
I did however forget to mention that my fuel pump does not prime when turng the ignition to on.
The pump not priming until you crank the engine over is normal. I thought it was odd but while installing my inline Walbro last week, I had to crank the engine over to make sure it was wired correctly and it gets no power to the pump until you crank the engine.
Old Jul 31, 2012 | 04:53 AM
tiggeryellow1's Avatar
Veteran: Army
I just updated my first post with the P0172 code before you posted.
I had my entire ignition system out with plugs inserted/grounded and checked that they were operating correctly, which they are.
The Walbro is about 500 miles old, and it is flowing well/creating the pressure needed to run. I have a DW300 I may throw in to verify.
I also have done a boost leak test to 35+psi with no leaks.
Thanks!
P0172 OBD-II Trouble Code
Technical DescriptionSystem Too Rich (Bank 1)
What does that mean?Basically this means that an oxygen sensor in bank 1 detected a rich condition (too little oxygen in the exhaust). On V6/V8/V10 engines, Bank 1 is the side of the engine that has cylinder #1.
Note: This DTC is very similar to P0175, and in fact your vehicle may show both codes at the same time.
Symptoms You will more than likely not notice any drivability problems, although there may be symptoms such as a misfire.
Causes A code P0172 may mean that one or more of the following has happened:
The MAF (Mass Air Flow) Sensor is dirty or faulty. Note: The use of "oiled" air filters can cause the MAF to become dirty if the filter is over-oiled. There is also an issue with some vehicles where the MAF sensors leak the silicone potting material used to protect the circuitry.
There could be a vacuum leak.
There could be a fuel pressure or delivery problem
Possible SolutionsPossible solutions include:
Inspect all vacuum and PCV hoses, replace if necessary
Clean the MAF sensor. Consult your service manual for it's location if you need help. I find it's best to take it off and spray it with electronics cleaner or brake cleaner(DO NOT USE BRAKE CLEANER). Make sure you are careful not to damage the MAF sensor, and make sure it's dry before reinstalling
Inspect fuel lines for cracks, leaks, or pinches
Check the fuel pressure at the fuel rail
Check the fuel injectors, they may be dirty. Use fuel injector cleaner or get them professionally cleaned/replaced.
Check for an exhaust leak before the first oxygen sensor (this is unlikely to cause the problem, but it is possible)
Old Jul 31, 2012 | 07:01 AM
ToddRhodes's Avatar
I'll throw out a wild guess - have you verified your coolant temp sensor is reading properly in EVOScan? At least on my old DSMs, the dash temp gauge worked off a different sensor than what the ECU used and if the sensor was bad that was used by the ECU, the ECU would literally dump fuel in because it thought it was -55 F outside or something like that. Just a thought.
Old Jul 31, 2012 | 09:02 AM
nismo05's Avatar
I was using an Omnipower as well. I switched to a GM 4 bar. Never had an issue sense.
