High idle after oem tb install
To make a long story short my old throttle body had a boost leak in the shaft seal so I tried fixing it n it didn't work. I bought a semi used throttle body from an evo 8 and after installing it my car would not idle below 2k, and sometimes it would jump from 900 to 1400 while coasting. I tried researching but got nowhere. Any insight? Thank u
Btw. I used the tps from my evo 9 on the evo 8 throttle body if that makes a difference
I don't have the evo scan but I know the tps isn't in the correct spot, I tried to adjust it by hand and listening to the idle but it still never goes below 2k
Did you follow a How To when removing/installing your TB? I ask because I am about to replace the seals myself with the MilSpec replacements and was reading through a How To and it says your idle could get be slightly off if the TPS is not installed in the same spot as before...
This link...Read item 1
https://www.evolutionm.net/forums/ev...aft-seals.html
Just a thought...
Just a thought...
Just a thought...
Just a thought...
Do you have any tips or tricks for him or was it adjusted by listening to the change in idle rpm (this is what the OP did already)?
llDemonll
Aug 17, 2015 08:54 AM
heavens turbo
May 1, 2010 10:46 PM
Blue Evo 8
Dec 3, 2008 06:59 PM
