door beeps with door open after disconnecting battery
Old Jan 30, 2013 | 05:45 PM
yacubkep's Avatar
Veteran: Air Force
I just had to replace the clock spring and head light switch on my car. It fixed my brights not working, SRS light turned off, and horn started working. so that was excellent.
now when ever the door is open even if the lights are not on or key isn't in ignition. it just constantly dings. WTF...
My key fob also quit working.......
Any one else have these issues?
Old Jan 30, 2013 | 07:26 PM
yacubkep's Avatar
Veteran: Air Force
did some googleing and found out there is a white box around the steering wheel that houses a spring loaded electrical connection???? not sure but it seems to make this go away..
Old Jan 30, 2013 | 08:49 PM
Cars4Life's Avatar
that means its broken, if that part is broken the door chime will stay on.
Old Jan 30, 2013 | 09:20 PM
Grimgrak's Avatar
I just bought one for 24$ it's the little yellow white plastic peice under the ignition two screws hold it on.
Old Jan 30, 2013 | 09:43 PM
spinner85's Avatar
Either buy it for cheap or tape it on. There are a few threads in here about that part. A lot of people just end up taping it. They break pretty easily.
Old Jan 30, 2013 | 09:50 PM
the_evodude's Avatar
had the same issue, taped mine as well
Old Jan 31, 2013 | 05:34 AM
yacubkep's Avatar
Veteran: Air Force
i looked for where it goes and couldn't figure it out... any one have a idea what its called so i can look it up and tape it in place.
Old Jan 31, 2013 | 06:10 AM
blowngasket's Avatar
that thing can break easily if some on is removing the Colum peice, its a small *** screw that holds the lil box on and can be quite a pest to get to. Its to tell you that you left you keys in the IG when leaving the car.
Old Jan 31, 2013 | 07:21 AM
Cars4Life's Avatar
Usually exactly what happens ^
Old Jan 31, 2013 | 02:56 PM
yacubkep's Avatar
Veteran: Air Force
found it. Tried tape, 30 below made it not sticky. I used Zip ties. see how long those work.
thanks for the help
lancer02Josh
Lancer Troubleshooting
Aug 5, 2020 10:17 PM
prowakeskater
Sep 29, 2018 02:25 PM
jimbo74
Jan 3, 2015 06:49 AM
live2teach
Jul 15, 2014 05:22 PM
White_KnightOZ
42
Jun 16, 2009 12:33 AM
