Evo 9 Taillights Issue
Old Feb 7, 2013 | 06:47 PM
Zro2Hero's Avatar
Hello, I just purchased a set of Evo 9 Taillights with the wiring and bulbs and put them on today. I realized that the driver side taillight has an issue where only one of the red driving lights turn on when I flip the headlights on, but when I hit the brake, the one that is not on will actually turn on. I know for sure it is the correct bulb because I tried using the bulb on the other side and it worked fine, I'm guessing there might be something wrong with the wiring but not sure what it could be, if anyone ran into a similar problem and has any input on what could be wrong, please let me know.
Old Feb 8, 2013 | 06:19 AM
egis's Avatar
when you pull out not working bulb take a look at contacts if you see greenish stuff it might be corrosion from the water or humidity in general.
Old Feb 8, 2013 | 11:16 AM
Zro2Hero's Avatar
That doesn't seem like the problem because I tried putting it in the other taillight and it worked fine :/
Old Feb 8, 2013 | 01:58 PM
TrippinKent's Avatar
Did you check your fuses? I'm not with my car atm so I can't check, but a car I used to have did the exact thing and it was a DRL fuse.
Old Feb 8, 2013 | 02:36 PM
Zro2Hero's Avatar
I was suspecting that for a bit, but then I put my original JDM tail back on and it was working fine, so I assumed it was the wiring on the IX USDM Tail light
Old Feb 8, 2013 | 03:07 PM
oh hmm, if the jdm is working, than I dunno haha..
Old Feb 9, 2013 | 11:50 AM
egis's Avatar
i got an idea.how about if you take whe whole tail light and start connecting bulb after bulb straight from the battery to see if its working?
Old Feb 9, 2013 | 12:17 PM
evotuner04's Avatar
15 Year MemberLikedLoved
im trying to find a link to a guy who had same issue locally, i'll try and find it asap
Old Feb 9, 2013 | 02:12 PM
Zro2Hero's Avatar
Sounds good, thanks a lot for the helps, appreciate it, last resort I'm going to try and undo all the soldering and redo it, and if that fails I'll probably just get new wiring, shouldn't be too expensive, its just a matter of being able to find someone that sells it
Old Feb 9, 2013 | 08:33 PM
evotuner04's Avatar
try this man, only 2 pages. if it doesnt help let me know. i'll shoot my buddy a message and see if he can post here
http://www.evomn.net/forums/showthre...79-Please-Help!
bluepeartype-s
Mar 16, 2015 09:01 AM
mplspilot
27
Jun 14, 2014 07:54 AM
jappaswat
Lancer Troubleshooting
Jan 22, 2010 02:22 PM
vicbdn
Mar 27, 2008 08:08 AM
N1te
Aug 13, 2007 06:44 PM
