A break from "show", want a little "go"
Okay, so I'm coming up on 60k, and have pretty much spent (some will say "wasted") my money on a lot of JDM bling and ARC, and am ready to take a break and work on performance. Other than front mount, turbo back, and usual bolt-ons, I have no performance parts. There is a shop here who does pretty decent basic tunes, and over this past month, I've accumalated parts that I want to put in and have this a basic tune done, until AMS comes back out and I can get a real one. Below is the list of parts I have. Any additions/suggestions? It is kind of a 60k service/ small performance upgrade combo. Also, I have very BASIC knowledge when it comes to mechanics (I'm all about sounds lol) and am still learning:
Walbro fuel pump
HKS timing belt
HKS balance belt
Kelford 272 cams
GSC springs and titanium retainers
AEM wideband
AEM tru boost guage/controller
AEM oil temp guage
NGK spark plugs
1000 cc low impedance injectors
Walbro fuel pump
HKS timing belt
HKS balance belt
Kelford 272 cams
AEM wideband
AEM oil temp guage
NGK spark plugs
Intercooler upper/lower pipe(ets), port your OEM exhaust manifold at map, Megan or any other o2 housing, ( since you said you have aftermarket TBE and intercooler ). Boost controller ( hallman mbc or grimspeed ebcs ), evo 9 bov or tial bov. These are bolt-ons. These and cams will make it around 330-350 whp or more at 20-24psi with stock turbo, pump gas.
Okay more specifically when I say bolt-ons, I mean pretty much all bolt ons (I already have all Intercooler piping, O2 housing, BOV, etc). I guess what I'm getting at is that I'm trying to make sure I have everything to support (1) upgrading my cams and (2) upping the boost some
My goal right now is probably around 350. Just a little power, as my primary focus is (bring it on haters) JDM parts and interior/Varis exterior right now because there is no track here in Hawaii, so no point in going bigger turbo until the Army sends me back to the mainland
I think you need to start with a goal in mind, also what you plan on using the car for (street, track, autox etc.) as well as a budget.
I think once you determine the above the upgrade paths are pretty strait forward these days and there is a TON of various threads on this type of stuff. I'd recommend searching around once you know the above questions and then put up your thoughts and have people comment. All I can suggest is do things right the 1st time, and well be realistic about your goals.
Origionally I was like 300whp, then it was ah 375 then it was 420 then I was like ah might as well go for 500 and I finally where I want to be not only with WHP but with my power curve.
Hawaii ah... would be fun to keep up with the street bike crowd through those twisties!
av00va
13
Sep 1, 2013 07:26 AM
