evo 8 hesitating? or clutch *video*
Old Mar 10, 2013 | 08:04 PM
serge l's Avatar
when i am in 4th or 5th gear a press the accelorator to speed up from 60 to 70ish around 3k rpm it jumps in rpm then goes back down and slowly goes back up as i accelorate
and sometimes when i hold the pedal something underneath the dash clicks, could it be some kind of throttle sensor or something
what do you guys think it is?
http://s1213.beta.photobucket.com/us...cc944.mp4.html
<embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf" flashvars="file=http%3A%2F%2Fvid1213.photobucket.c om%2Falbums%2Fcc461%2Fek-serge%2F20130310_174850_zps4b0cc944.mp4">
Old Mar 10, 2013 | 08:11 PM
dozena's Avatar
Boost leak? Looks like it gets up to certain boost then just lets go?
Old Mar 10, 2013 | 08:15 PM
hiboost2.0's Avatar
A boost leak will not allow the rpm to drop back down. If there is a leak it will hit a specific psi based on how big the leak is and not go any higher. It will kinda feel like the car is falling on it's face acceleration wise.
Old Mar 11, 2013 | 12:08 AM
civicej8's Avatar
maybe your clutch? how does your clutch feel? your boosting pretty hard in 5th also.
Old Mar 12, 2013 | 12:13 AM
serge l's Avatar
i bearly hit boost
Old Mar 12, 2013 | 11:49 AM
BEKevo's Avatar
Very hard to diagnose over the internet... But do a boost leak, and check the BOV/ DV, to see if it's holding pressure. Also when is the last time you checked your plugs/ gap? Could be ignition break-up, among the many other things.
Also are you monitoring AFR? If so.. whats your AFR looking like when you get around that area of the rev range?
Is your clutch shot or not? You need to figure that out.
Logs of whats going on,in that particular time frame, would help out tremendously.
Dirty_Evo
For Sale - Cars For Sale
19
Jul 31, 2014 11:45 AM
heel2toe
60
Jun 12, 2013 06:16 AM
serge l
Mar 16, 2013 08:45 AM
MOB EVO X
For Sale - Part Outs
Mar 13, 2013 08:46 AM
