No Start Issues
Old Mar 19, 2013 | 07:47 AM
CeeWhizzle's Avatar
No Start Issues
So a couple days ago I was driving to work and as soon as I stopped at an intersection a block away my exhaust sound changed to a "diesel" sound (I also have an external waste gate) rather than the smooth quick sound. The idle didn't really drop a whole lot, maybe 200-400rpms and it was quite slow when accelerating. I assumed that it was one of my injectors going and so I parked it at work, grabbed one of my extra Evo 6 injectors and cleaned it up overnight to be put in. I started it up again, hooked up evoscan and turned on each injector actuator to see which cylinder it is. 4,3,2 made changes to the idle and made the vehicle shake and when I did #1 it made no changes.
The next day, my Evo wouldn't start at all, however that morning the temperature dropped from -10 to -20 and it is currently staying like this for a few days :/ but before I left it sit over night, she started up just fine with no problems.
So yesterday I replaced the #1 cylinder injector with the Evo 6 one and then attempted to start. This time it had even more of an issue starting, it would hardly even fire.
I do remember accidently pressing the fuel pump actuator but nothing happened when I did, so I doubt that has anything to do with the current no start and no fire. She cranks completely fine and battery is at full.
So today, my plan is to pull the rail, see if there is fuel coming out and if there is - I'll be pulling my plugs and spark plugs out. Anyone have any input or suggestions on this issue?
Here is my mod list:
-Evo Power Mods version 2 exhaust waste gate dump
-GSC 272/272 cams
-Hallman manual boost controller
-AMS Front Mount Intercooler (3.5" greddy race core with AMS custom weldedend tanks
-AMS Lower Intercooler pipe
-Megan Racing 3" downpipe
-Ultimate Racing 3" exhaust with high flow cat and vibrant muffler
-Apexi vortex turbo intake
-Factory Evo9 mr metal BOV
-Walbro 272 Fuel Pump
-Exedy Organic clutch and ACT lightweight flywheel
Old Mar 19, 2013 | 08:05 AM
CeeWhizzle's Avatar
I hooked up Evoscan, applied the Fuel pump actuator and I can hear the fuel pump run. So Fuel pump is most likely good. I also did a short datalog while cranking the car, would this be able to show anyone the issue?
I can email the CSV file to someone that is willing to help me out :P
Old Mar 19, 2013 | 10:49 AM
CeeWhizzle's Avatar
Update: There is plenty of fuel in the rail and all my injectors are working.. Does the stock COP system usually have issues?
Old Mar 19, 2013 | 11:31 AM
CeeWhizzle's Avatar
Oil found in cylinders 2,3,4 and plugs are covered in it.
Old Mar 19, 2013 | 11:38 AM
SW20Mike's Avatar
Veteran: Air Force
Compression check? Is your coolant contaminated? I'm thinking blown HG or engine is damaged in a way.
Old Mar 19, 2013 | 11:44 AM
CeeWhizzle's Avatar
Just checked compression, Its all 139-170. Coolant is clear and not contaminated. I kind of think its a blown HG... but I drove fine for half a day with it idling funny... There is quite a lot of oil in Cyl 3 though :/.. My plugs were dripping when I pulled them. I'm going to find a way to suck all the oil out and do another Compression test to make sure its not my rings.
Old Mar 19, 2013 | 11:59 AM
4RETECH's Avatar
Do a leakdown test.
That way you could determine if its rings, intake valves or exhaust valves if you have excessive leak down.
Also, you checked injectors with a noid light?? Remember there is an injector resistor box between the ecu and injector.
Old Mar 19, 2013 | 12:02 PM
CeeWhizzle's Avatar
My injectors are fine I hooked them up to a battery and they were working, and I have new ones on the way anyways. I have no way of doing a leakdown test :/
Old Mar 19, 2013 | 12:35 PM
4RETECH's Avatar
That's great. But the signal comes from the ECU not the battery. Get a injector noid light to confirm.
Old Mar 19, 2013 | 12:41 PM
CeeWhizzle's Avatar
Why is this important? There is a large amount of oil in 3 out of 4 cylinders. Injectors are the least of my worries right now.
Old Mar 19, 2013 | 01:12 PM
4RETECH's Avatar
Okay, good luck to you.
Old Mar 20, 2013 | 12:04 PM
CeeWhizzle's Avatar
Got it to start. No blown head gasket. Pressures are all 140-150 accross. However I still have massive engine vibration and loss of power.
EvolutionIXMR06
Mar 24, 2014 11:40 AM
DropThatHammer
Jan 7, 2014 07:31 PM
DagYo369
Jul 31, 2013 01:29 PM
gvr4737
Dec 17, 2012 07:46 PM
IndyEvo66
61
Jan 14, 2011 09:36 AM
