Hesitating/stuttering at wot
Old Mar 25, 2013 | 09:22 PM
Mikey15's Avatar
Hey guys , just recently started having problems . My Evo drives fine and was flawless till about a week ago I noticed whenever I pin it and allow the throttle to open 100% , when the car hits full boost it starts to stutter almost. So I changed the plugs out and the oil. Nothing changed however I think it may have gotten worse .
I put iridiums in and I think that may be the problem, however The weather here has been fluctuating ridiculously, 15-20 degrees celcius over night ... So
Im going to try reflashing the ecu and see if that helps .
Does anyone have any other ideas?? Anything will help !
Thanks for your time .
Old Mar 26, 2013 | 12:30 PM
BrokenTurbo's Avatar
check your couplers, I had this happen to me about a week ago, one of my tbolt clamps wasnt tight enough so when I went WOT I had a nice boost leak, then the clamp failed. do a boost leak test 5 PSI over your target boost. good luck and post your findings if its something else.
Old Mar 26, 2013 | 12:35 PM
5LEEPERISAH23I's Avatar
its probebly bad plugs, Id start with replacing them, if that isnt the issue the next thing id do is get a boost leak test done to see if there are any leaks, if that doesnt work test your coil packs "doubt it is that but you never know"
Old Mar 26, 2013 | 12:36 PM
chu's Avatar
chu
Both good advice. Check for boost leak, and plugs, and report back.
Heirthos
May 13, 2017 12:49 AM
mrj1mbeam
Jul 24, 2013 06:05 PM
vnguyenl
21
May 26, 2012 03:13 PM
crazy j type-X
Feb 22, 2012 08:22 PM
AllBlak
16
May 29, 2006 04:02 PM
