Low idle vacuum?
Old Apr 10, 2013 | 08:37 PM
Viegasjuice's Avatar
Low idle vacuum?
So i have the aem tru boost gauge and reads -10 at idle an about -17 to -20 at cruise....anything seem off here? Makor mods are gsc s2 cams, buschur tbe catless, ets intercooler an piping, mini battery
Old Apr 10, 2013 | 09:08 PM
ReidFletcher's Avatar
Your cams are to blame. Everything is normal.
Old Apr 10, 2013 | 09:11 PM
Awesome..was thinkin possible boost leak
Old Apr 11, 2013 | 05:53 AM
Jimmy Javelin's Avatar
No offense but dont take one persons word,
you wouldnt go to one mechanic you've never met
for automotive advice on your evo.
Whens the last time you did a boost leak test?
Have you always had those vacuum readings?
Have you done maintenance on your car recently, taken
off hoses, maf, air intake etc?
If you had a boost leak,
think about it, the pressure would be going back to equilibrium if there was a leak,
correct me if I'm wrong. Get a water bottle and spray around the engine bay and see
if you notice anything.
Old Apr 11, 2013 | 06:56 AM
Raptord's Avatar
Vac sounds about right depending on idle rpm. lower rpm will read lower vacuum.
Old Apr 11, 2013 | 07:08 AM
meckert's Avatar
All good info above--check and report back. In the event all is well and nothing else comes up--there are some options. Do you have cam gears and how did you determine the vacuum was low? ( its sounds low-- but what was the comparison that cause you to ask the question?)
Old Apr 11, 2013 | 08:26 AM
c0ke's Avatar
I have the same vaccum levels, cams are to blame you're fine.
Old Apr 11, 2013 | 11:29 AM
Idles at about 1k..always been like this, curiosity just struck so i wanted to get opinions.
Old Apr 11, 2013 | 01:38 PM
c0ke's Avatar
yes, the lopes of the cams and the raised idle needed to run them reduces the vaccuum at idle significantly and it's completely normal
Old Apr 11, 2013 | 03:13 PM
Awesome, thanks
Old Apr 16, 2013 | 12:06 PM
slimjim1804's Avatar
Cams. both evos I have had had kelford/hks 272s, both around that vac.
Posted from Evolutionm.net App for Android
Old Apr 16, 2013 | 01:50 PM
kanovic's Avatar
+1 for cams mine is -10 or so
bluedemon199
May 4, 2017 07:08 PM
OPENA(671)
Sep 5, 2013 09:54 PM
EvoJoeIX
Mar 16, 2013 06:34 AM
EvoIXPilot
Jan 8, 2013 05:40 AM
Oracle1
Apr 6, 2008 08:39 PM
