evo5 juddering when turning right
Old May 14, 2013 | 02:10 PM
Llew's Avatar
when I turn only to the right my car judders and it gets worse as speed increases. the whole car judders really bad. what cud it be?
Old May 14, 2013 | 02:28 PM
SilverShadow03's Avatar
Is the juddering coming from the front suspension?
I would get under your car and make sure all of your suspension, steering and wheels are nice and tight (to spec obviously) and make sure your wheel bearing(s) are not going out on your as well.
Check your front axles as well.
Someone else can chime in with other suggestions.
Old May 15, 2013 | 01:53 PM
Llew's Avatar
seems like its from the front right wheel and you feel the juddering in the whole car
Old May 15, 2013 | 01:54 PM
Llew's Avatar
the car drives perfectly when I turn to the left or go str8
Old May 15, 2013 | 01:57 PM
NightHawk's Avatar
sounds like a wheel bearing issue at high speeds
Old May 15, 2013 | 04:01 PM
Pure EvoIX's Avatar
wheel bearings or warped rotors.
Old May 17, 2013 | 09:42 AM
Llew's Avatar
it isn't warped rotors or wheel bearings. ive had those other issues before in my other car, Lancer GSR. im experiencing a violent juddering shakes the entire car only when turning left.
car has brand new rotors all round and new tie rods and steering ends. and just the week before drove without those issues.
Old May 17, 2013 | 09:51 AM
misterevo8's Avatar
sounds like an axle to me.
Old Jul 13, 2015 | 01:26 AM
Gari's Avatar
Hi, I know this is an old post but what was the result of the juddering? I've got the exact same problem with my 5 and believe it's the transfer box
Old Jul 17, 2015 | 02:34 PM
EvoIV_97's Avatar
Veteran: Air Force
My 4 had two issues causing juddering. First was that there were only three bolts holding the engine to the trans when I bought it. Second was the bolts inside the transfer box came loose, but that was more of a clicking than juddering.
icy_comet
Apr 8, 2016 11:32 AM
w0LF.e
Mar 30, 2016 07:52 PM
abrar
Feb 9, 2016 04:49 AM
jameswwt
41
Feb 5, 2012 06:31 PM
volkskid
Apr 5, 2008 11:50 AM
