Evo 4 Oil Pressure Problems at idle
Old Jan 31, 2014 | 12:19 PM
Capes's Avatar
Just recently the oil pressure warning light would come on at idle once the car was at normal running temp but would go off again if revved or driven. I had an electronic oil pressure gauge installed & once the car was warm it was reading 0psi at idle.
After a bit of research online I was pretty convinced that the least of my worries was I needed a new oil pump. But before I went any further I dropped the sump off & pulled the oil intake out, which looked to be partially blocked. So I gave it & the sump a good clean, put it all back together, filled it up with fresh Castrol Magnatec 10-40 put on a new oil filter & it seems to have solved the problem. The oil pressure gauge now reads around 10psi at idle which I hope is a crap load better.
I was wondering now if anyone out there knows what the normal oil pressure readings are, as I can't find any info about this.
The car is un-modified apart from an HKS Pod filter, BOV & a full 2.5" Ralliart Exhaust system.
Any help would be much appreciated.
EVOLVE
Old Feb 1, 2014 | 07:11 AM
EvoVan's Avatar
You should see about 14-28 psi at idle. Expect to see highest pressures after a cold start then it evens out (around 23-25 for me). That said my oil is a lil thicker than yours.
Old Feb 1, 2014 | 12:35 PM
barneyb's Avatar
Well, for 22 year that I know of the oil switches on the 4G63 have been set to come on at 4 psi.
Old Feb 9, 2014 | 02:27 PM
patryko's Avatar
send me your adress email i send you service manual for evo 4 if you want
RSMike
138
Jul 20, 2025 09:19 AM
McKenny14
Oct 17, 2014 01:15 PM
dryad001
10
Oct 30, 2012 08:32 AM
Shizzle
Dec 13, 2009 08:32 PM
Knightr
19
Aug 11, 2009 10:32 PM
