Exhaust & header wraps
Old Apr 12, 2014 | 12:31 AM
wowzers's Avatar
Hi guys,
i bought a few rolls of exhaust/header wrap.
Im thinking of coating the exhaust manifold & down pipe.
however I've watched this video regarding mild Steel;
Any issues with the OEM cast or stainless steel?
will it shorten the life also?
thanks
Old Apr 12, 2014 | 07:35 AM
thepoint4life23's Avatar
Well the down pipe should be stainless steel not mid steel. also with coating it you should have no issues. i have never heard of anyone with issues coating
Old Apr 12, 2014 | 11:21 AM
slowsrt4:('s Avatar
your stuff should be stainless steel, no worries might get a little surface corrosion, but will be good
Old Apr 13, 2014 | 04:41 AM
wowzers's Avatar
well, now you have!… that pommy bloke in the youtube link has!
that looks pretty bad…
i guess you just gotta stay away from mild steel.
Well ill wrap the cast OEM exhaust manifold and see how it goes
Old Apr 23, 2014 | 11:00 PM
TimIacobucci's Avatar
Those are off and old NA thin wall exhaust. The material and it's thickness have a huge affect here. It will cause more heat to be retained in the metal that is true and possibly cause cracks in poorer quality iron castings. Most purpose built turbo stuff that is stock or decent aftermarket will hold up fine though. It makes a big difference in underhood temps and all that goes along with that, plus reduced burn hazard is very nice. Also with mild steel if you paint it with a high temp paint before you wrap it it will go a long way towards preventing oxidation.
Old Apr 24, 2014 | 04:28 AM
wowzers's Avatar
Yeah I've got a roll of header wrap.
will get it done once i get the O2 housing on. (may wrap that too)
since i looked into ceramic coating and it aint cheap
Old Apr 24, 2014 | 05:51 AM
DSMolition's Avatar
^^ this is key, i was going to post this a while back but never did. Have been doning this on mild stuff for a while and it has held up. All though I don't drive the vehicle in winter. There is also a wrap paint that you can use after its wrapped to help seal it off from mosture.
Old Apr 24, 2014 | 03:38 PM
wowzers's Avatar
yeah i haven't got anything mild steel and probably would never install that material.
im assuming with the cast stuff… obscure locations on the body panel would rust out earlier than the stock manifold, wrapped or unwrapped.
Paint in spray form?
never heard of it.
emac227
Jan 24, 2016 03:52 PM
Brandonm
Nov 10, 2015 09:29 AM
si2nr
08+ Lancer Show / Shine
Sep 21, 2014 08:37 PM
Tampavw
Jul 19, 2014 04:46 AM
