Shifter vibration @2k-3k rpms every gear
Old May 16, 2014 | 02:36 PM
Rloera12's Avatar
does anyone know what could be the issue? I've had this issue for about 3months now and can't seem to figure out exactly what is causing this. Ive searched on google and here and can't confirm exactly whats wrong. i can feel it right on the shifter on every gear between 2k-3k rpm especially when i try to gas it but after 3k it goes away completely?
Ive had a few people check it out and some said its my drive shaft others my cv axles?
Another experienced member here told me it might be my clutch/flywheel or my transfer case.
my mounts seem to be fine (from a glance i have not taken them off)
also i checked under the car and my driveshaft has been hitting my O2 sensor and broke it.
any ideas? thanks ahead
btw if there is a thread where this was already answered please link it
Old May 16, 2014 | 06:30 PM
egis's Avatar
did you perform 6 to 5 speed swap recently?
Old May 16, 2014 | 09:30 PM
Rloera12's Avatar
Good question. Yes the car has a 5 speed swap it was originally a 6spd
Old May 19, 2014 | 12:31 PM
rongdoer's Avatar
If its moving enough to break your 02 sensor than thats more than enough to feel it in the car. Try some driveshaft carrier support bushings. Even without this problem you should get them. Stops a lot of drivetrain movement.
Old May 19, 2014 | 03:46 PM
Rloera12's Avatar
Thanks for the imput so maybe it the carrier support bearings? I think i will start there then
Would the torque solution ones be good?
http://www.amsperformance.com/cart/t...ts-ev-dsb.html
Old Jun 5, 2014 | 05:43 PM
Rloera12's Avatar
So i just installed the bushings but i can still feel my shifter vibrating, but not as bad any other pointers? Thanks
Old Sep 10, 2014 | 12:50 PM
Rloera12's Avatar
turned out to be my flywheel. was wearing unevenly
Duke204
Mitsubishi TC-SST Discussion
Jul 6, 2015 12:29 PM
EvoCorseIX
Nov 27, 2014 10:23 AM
killerpenguin21
10
Apr 17, 2013 10:24 AM
recompile
148
Jul 12, 2009 09:23 PM
Import Junky
31
Jun 29, 2009 06:56 PM
