Spun another bearing.
Old Jun 18, 2014, 10:06 AM
phildo's Avatar
Lost oil pressure on my morning commute, the sound of knocking alerted me
This motor only has about 2-3k on it, last time it did this I just had the crank reground and new bearings installed. I'm feeling like the car is cursed at this point.
Options:
1) Rebuild the 2.0l, go back to stock, sell it, get another Evo that I trust more.
2) Go big, build a 2.3 and hope for the best
3) Cut my losses and sell it/part it out
If you have gone through something like this before please chime in, my car is just sitting outside making me depressed.
Old Jun 18, 2014, 11:25 AM
EatSleepBoost's Avatar
I say a 2.4 build. Blocks are cheaper and you can build it strong. That way you won't have to use any of that bottom end that scares you
Old Jun 18, 2014, 12:22 PM
roach85's Avatar
2.4LR with a stock frame turbo like a Green or Black I have always wanted. Id also say go with a 2.4LR
Old Jun 18, 2014, 12:32 PM
ronaldo9's Avatar
I would figure out what went wrong to begin with and salvage anything undamaged and try again with the setup you had.
Old Jun 18, 2014, 12:46 PM
phildo's Avatar
Thanks for the replies, I guess I am going to start with cracking this motor open and seeing what can in fact be salvaged, and let that decide between a fresh 2.0l or 2.4
phildo's Avatar
Any recommendations on a place to start looking for a bargain 2.4 to start working with if need be?
Old Jun 18, 2014, 01:31 PM
Biggiesacks's Avatar
what ever you do, dont cut corners this time.
Old Jun 18, 2014, 03:20 PM
andrewzaragoza's Avatar
did you replace your oil cooler last time you spun a bearing? if not then that probably caused your 2nd failure.
Old Jun 18, 2014, 06:42 PM
Berns82's Avatar
I did a similar rebuild with a 2.4 and my fp black. Lots of $ and time later, I'm very happy. I do know where you're coming from, I had a lot of stupid issues that still pop up. I could own a 10 by now....good luck
Old Jun 18, 2014, 07:12 PM
bbong's Avatar
I'd hit up tscomptuned he builds 2.4s
Old Jun 18, 2014, 07:30 PM
ckevo8rs's Avatar
+1 but you'll have to wait. He is building mine
Old Jun 19, 2014, 10:09 AM
boostedinwyo's Avatar
****ty luck man but if I were you I would go to someone new if you havent already Engines typically just dont spin rod bearings after 2 to 3 k on them Poor workmanship or incorrect assembly is probably the issue
Old Jun 19, 2014, 11:20 AM
gsrboi80's Avatar
It is not cursed as other said it was improperly built judging by your first post
If you are still looking to "cut corners" to get it running I suggest parting the car out now and cutting your losses as you stated
Old Jun 19, 2014, 11:29 AM
Prime5traw's Avatar
I actually just did the same thing and just got done rebuilding the engine all manley parts i say rebuild it with good parts. Make sure the gaskets are being assembled correctly. IE oil pickup
Old Jun 20, 2014, 08:57 PM
SmurfZilla's Avatar
My history with this platform is shorter then some but I've gone through alot more then most. 1) figure what went wrong on the this time. 2) If you are building consider the fact that you may need to have someone with impeccable credentials build it, something your doing may not be right.
3) like has been said.......dont cut corners.
Let us know what went wrong if you can figure it out.
Quick Reply: Spun another bearing.
