Wot 2nd gear around 4-5k rpm sputter and rpm goes down
What's up guys I'm having this issue for a while when in 2nd gear wot around 4.5k rpm it sputters and the rpms starts going down in 3rd gear it sputters but rpms keep climbing, i did all the maint when I first got the car fluids, timing belt , water pump, plugs and wires and it hasn't been 1k miles yet... The previous owner did a FMIC and drop in filter so I figure since it had no MBC that why it sputtered so I install a hallman MBC it's set at 12psi and it's still sputters some ppl say it's the coil boot that need to be replaced can anybody confirm this. It's a 9mr when I bought it had 130k I've only added maybe 300 miles cuz I mostly keep it in the garage
any obd codes popping up? Have you done a boost leak test? What did you gap the plugs to?
I had the same problem just about exactly what you're having. And who ever told you to replace your coil is correct. When I had this issue I up graded to the spoolin-up cop kit, I would suggest you do the same. If you're going to replace both coils it won't be much more money for the cop kit anyway.
Yes go spend money on parts before ever actually diagnosing the problem. That sounds like the way to go.
Yes this would be beneficial. Which I did do Diag on mine with a launch scan tool but not everyone has access to a tool like that. But yes I think he has the same problem I had but obviously cannot guarantee it. Then gave him my opinion about the coils if he is going to replace them. No one told him to throw parts at it till it's fixed.
In his first post he had suggested that he was going to replace parts, and you said this, which is what garnered my sarcastic response.
My response wasn't completely aimed at you. I asked OP 3 simple questions. The answers to those questions are critical for actually diagnosing his problems. He did not respond.
Did you actually plug in a code reader? The light could not be on for various reasons. What method did you use to perform your boost leak test, and to what PSI did you test it to? Some people seem to think reving it in neutral and listening for leaks qualifies, it does not. I asked WHAT you gapped your plugs to, not if you gapped them. Cheers
Yes I connect the scanner no codes not even pending codes, boost leak test I used the homemade method they have on the DIY section where you put the cuppling on the turbine and and put compressor air hose, and plugs are gapped to .25mm
Miss fires and bad coils generate codes, so either your ecu was reset (power disconnected) or you have some other issue. You didnt answer what PSI you tested it at, many leaks only happen at higher levels. I believe testing to 30psi is standard for most shops. Your gap is a huge red flag. Factory manual calls for .7-.8mm so right there is a huge problem.
