Titanium exhaust manifold studs?
Old Jul 10, 2014 | 11:12 AM
Boostlife4g63's Avatar
So I'm preparing to swap exhaust manifolds cuz I hate my Meghan, Im looking into head studs that will NOT rust and although they make stainless steel I was wondering if they make titanium!!!!!!!!!!!! anyone ..... anyone
Oh and does anyone trust a company other than ARP for there studs?
Old Jul 10, 2014 | 12:01 PM
Ev0ikon's Avatar
Stainless steel is fine. Just be careful not to mess up the softer aluminum head! :}
Old Jul 11, 2014 | 11:36 AM
True, thanks for the warning.
Old Jul 11, 2014 | 12:04 PM
leemaster's Avatar
Veteran: Army
I used a bolt Zinc(No nuts) and coated it with anti-sieze, so far its been holding up well.
Old Jul 11, 2014 | 12:41 PM
nirvancol's Avatar
If you use stainless steel studs, you should try to avoid using stainless nuts. If you do, there's a good chance they will gall and seize (common with stainless-on-stainless threads). There are lubricants and coatings to help with this, but I haven't had much luck in my limited experience with them. But if I were going to do it, I would use whatever lubricant is recommended and thread them on by hand, then use hand tools to finish threading them on (don't use power tools to run the nut in).
Old Jul 11, 2014 | 01:12 PM
thatguy5's Avatar
titanium can get very brittle even moreso than SS depending on quality. ARP sells chrome moly headstuds which I highly suggest
Old Jan 21, 2015 | 10:19 AM
Gtizks's Avatar
ive never had a problem on previous builds with ARP
2006EvoIXer
May 31, 2017 08:49 AM
Mr. Move
Feb 13, 2017 12:49 PM
DaltonD19
Midwest Region
Nov 16, 2016 11:19 AM
h4ckluserr
13
Mar 15, 2016 12:22 PM
MysticKnight
Dec 5, 2015 04:42 PM
