FP BLACK brothers chime in!!
BB is usually better and less prone to failures due to oil hiccups. However a lot of members on the forum seem to have had issues during idle with oil accumulating on the compressor side that leaks from the gas piston seal. The seal is so sensitive that it only takes 0.5psi of crank case pressure to open it. I'm starting to think that FP needs to make a new oil drain to go with the BB Black or to make the restrictor line a bit smaller for the oil feed. Pressure is still building up in there and causing oil to come out. I have a Saiko Michi -10 catch can setup on the intake manifold side and the intake side as two separate cans. There should be no crank case pressure, nor should there be oil coming from my compressor housing on this expensive of a turbo.
[WTB] FP black, new or used.
Black_EVO_MR
Jul 22, 2016 01:44 PM
WTB[Northwest]: Wtb JB FP Black
Mecheng1993
Aug 25, 2015 04:02 PM
twinturbogreg
16
Nov 1, 2010 11:05 AM
