car wont start after intake install
so i installed a aem intake earlier today and everything went fine until i tried to start the car. it will turn over to try and start up then die right away, i did wipe the inside of the maf since it looked gross but the metal thing in the middle is intact and all the connections are made, is there something that im missing somewhere or did i mess up the maf when i was cleaning it? any input is appreciated
ps. the maf plug is plugged in correctly i checked it like 4 times and also tried starting the car without it plugged in with the same result
Alright when I get off work I'll pick up some maf cleaner and see what I can do, I'll keep it posted letting you guys know if it works. If anyone has something else to add feel free. I don't have alot of experience with maf's
Wanted to step back from the MAF part and ask about the UICP(upper intercooler pipe). Did you have to remove the pipe to install the intake, and did you connect them afterwards? Evo's absolutely refuse to run without the intake pipes connected. I have ran my Evo without the MAF plugged in and it will start but runs crappy (starts non the less). Hope this helps a little.
Do you have a means for monitoring the iat (evoscan or my obd2 scanner displays it too) this would be the easiest way to check if the maf is now bad. That or you could test the maf via a multimeter can't remember if I got the procedure from the service manual or alldata but there should be one in the service manual.
i figured it out, my dumbass broke off the camshaft position sensor when i was either pulling the stuff out or putting it back in, will be getting the part in a day or two and then hoping the maf isnt bad -_- thanks for all your input guys
alright got the new sensor put in and the car started right up and is running perfect just need to get my tuned tweaked a little bit since my afr is off a little bit. running 11.3 when it was 10.8 at WOT thanks again for the help and my *** is never touching the inside of a maf ever again haha
Ev1LEv0
61
Aug 15, 2011 04:04 PM
def1
Dec 30, 2010 12:34 PM
