evo 8 leaking oil need help
Old Oct 10, 2014 | 02:38 PM
eisnikesb's Avatar
hello everyone. So the other day I noticed my car was leaking oil or it seemed to be an oil like substance only like a few drops every 8 hours. I got underneath the car and I noticed on the right side of the engine where the lower serpentine belt is near the oil filter it is all wet as well as the oil filter and A arm. I included some picture so you can see what I was talking about.
Thanks in advance for any help you can provide.
Attached Thumbnails evo 8 leaking oil need help-20141010_161249-1-.jpg   evo 8 leaking oil need help-20141010_161320-1-.jpg
Old Oct 10, 2014 | 03:09 PM
LCS's Avatar
LCS
You must take the serpentine belt and plastic side covers off to check it the oil pump is leaking anywhere.
Old Oct 10, 2014 | 03:13 PM
EatSleepBoost's Avatar
Oil will tend to spray down and back due to gravity and the wind while you are driving. Chase it forward and up to find the source. Best bet is to clean everything with some brake clean and a rag then start the engine and let it idle for 20 mins or so then recheck for a leak. Its easier to find a leak if the oil isn't sprayed everywhere.
Old Oct 12, 2014 | 06:43 PM
Colorado Sparky's Avatar
Agreed. I would check engine oil and make sure the level is OK. Then clean everything. Drive it 10 miles or so and check to see where the oil is coming from.
_des_
May 30, 2014 07:51 AM
fishtaco254
Oct 25, 2012 10:01 AM
armysoldier1073
Oct 7, 2010 09:04 PM
cpdevo31
Aug 22, 2008 06:57 PM
Turbo Kyle
Aug 18, 2008 08:07 AM
