No SES on start-up. Need Help
Alright so I took my Evo to emission and it passed everything other than, the visual lights test. Now I had never noticed it before or I would have tried to figure it out before taking it to the test station. At the time, car had nothing in it other than a forge bov and intercooler. The ses light does not come on for the few seconds after startup like it should so I failed the test. I tore the dash apart and checked the bulb, which was good, replaced it just in case, still not light. I can put a multimeter on the circuit where the bulb makes contact and it gets power there but it's not illuminating the bulb. I figured maybe someone had turned it off through a flash but having power at the circuit made no sense to me. I need help, I don't know what else to look at here.
bulb has 12v on one side then the other side blue white wire goes to ecu pin 22 switched to ground by ecu
pin 12 on left hand side connector behind dash is blue white
So I should be able to jump the blue/white wire at pin 12 to ground and the light should work then. I traced the wires best I could on the diagrams in the service manual. Could the ground control have been disabled by flashing the ecu?
yes but the light will then stay on , no flashing shouldnt disable it
Even if the oil pressure sensor failed, it should still light up in the cluster with key on. All the cluster does when you turn the key on is a bulb check.
no it wont still light , its dependant on a ground to light it , the oil pressure sender grounds it when oil pressure is low. theres is no bulb test on evo1 to 9
take the wire off the sensor then get a piece of wire join into the connector and ground it light should come on with ign on of course .
geevolution
Dec 31, 2009 05:31 PM
