Fuel sending unit -6 to stock fitting?
Old Jan 26, 2015 | 07:44 AM
DSMolition's Avatar
What fitting do i need to go from the stock fuel sending unit to a female -6 AN line. I’m upgrading my fuel lines and using the stock sending unit for now. I know they make them just don’t remember where they were at.
Attached Thumbnails Fuel sending unit -6 to stock fitting?-fuel-sending-unit.jpg
Old Jan 26, 2015 | 07:59 AM
DSMolition's Avatar
What i really just need to know is the stock fuel iine 3/8" or 5/16"? can anyone conferm?
http://www.jegs.com/i/Russell/799/640860/10002/-1
Old Feb 10, 2015 | 09:52 PM
KentStateTsi's Avatar
Veteran: Army
I am looking at doing the same thing. Getting rid of my double 255's and going a single 450 in the stock hanger. I want to know the same thing. I don't have my old sender around to measure. Hopefully someone replies that has used them.
Old Feb 11, 2015 | 09:00 AM
DSMolition's Avatar
I wanted to do it the right way and get the fitting above that i linked but i ended up just cutting the -6 female end off and it fits perfectly around the sending unit nipple and used two hose clamps. I’m sure if you are going to a -8 line you would need the rite adapter. One thing I noticed is you would want a 90 degree at the top of the hanger to make the installation because of the angle the fuel nipple comes out of the hanger.
I know -6 is not a lot larger than the stock size but it is larger and the line I used is made for e85. I added a fuel lab filter by the rail to help with the black goo issues I sometimes get from e85. I never have liked the fuel filter in the hanger. I don’t think you can even service those.
Old Feb 11, 2015 | 09:53 AM
michaelrc51's Avatar
Originally Posted by DSMolition
What i really just need to know is the stock fuel iine 3/8" or 5/16"? can anyone conferm? http://www.jegs.com/i/Russell/799/640860/10002/-1
Stock return is 1/4"
Stock feed line is 5/16"
Old Feb 11, 2015 | 09:54 AM
I have to look it up, I will get you a part number later today. It is a push lock to AN fitting.
Old Feb 11, 2015 | 04:24 PM
Fast_Freddie's Avatar
Veteran: Navy
This is the fitting you need to go straight off the OEM fuel pump housing, it is 3/8" ID SAE to -6AN
http://www.jegs.com/i/Russell/799/64...oductId=819594
The other fitting link above, is for the stock feed line 5/16" ID SAE to -6AN underneath the car...
This fitting from extreme psi will adapt the oem bubble flare in the engine bay to -6AN to go from the stock hardline to the rail
http://www.extremepsi.com/store/prod...at=1559&page=1
Old Feb 11, 2015 | 04:59 PM
I used the other kind, the one that isn't quick disconnect. See part #644110 on this page.
http://russellperformance.com/mc/ada...injected.shtml
Old Feb 11, 2015 | 05:10 PM
Veteran: Army
I was looking at the threaded retainer ones as well. How does it hold up? I'm afraid cranking it all the way down will crack the outlet.
Old Feb 11, 2015 | 05:31 PM
Yeah, on the pump hanger side you might want to consider the quick release one that Freddie provided, part numbers also found in the section above the one I used.
I went with a Squash Performance double pumper so I didn't use the OEM hanger. The fitting I used was one the factory 5/16" hard line under the car and it was pretty hard to get it on so I would advise against using that fitting on the plastic pump hanger assembly.
Old Feb 14, 2015 | 12:29 PM
Veteran: Army
Just installed the jegs 3/8 to -8 fitting. Double o-ring and a pain to get on. Be very careful pushing/pressing it on.
Old Feb 14, 2015 | 12:44 PM
evo_nation's Avatar
Part number?
Old Feb 14, 2015 | 12:49 PM
Veteran: Army
http://www.jegs.com/webapp/wcs/store...&storeId=10001
With the -8 you will have to trim the metal housing retainer ring. I can't say for sure about the -6 because I didn't use it.
555-103101 Is the -6 quick connect
555-103102 Is the -8
Russell has the same thing in blue.
Old Feb 17, 2015 | 04:30 PM
Veteran: Navy
IMHO -8AN is overkill for the oem hangar assembly because of the ID of the hangar assembly itself...
Old Feb 17, 2015 | 05:56 PM
Veteran: Army
You're probably right and I was waiting for somebody to say it. I have -8 already ran from the double pumper and I'm not going to replace it.
