SD intake, vacume lines? what to do with them?
Old May 18, 2015 | 10:12 AM
alexc's Avatar
Im gathering up bolt on parts before installing them and getting tuned. I'm switching to speed density in the process
I was wondering for the SD intakes that do not have the plugs for the lines that hook up to the stock, and some aftermarket intakes, what do you do/what happens with those lines/ connections?
why are they not there on SD intakes?
Can i use a larger aftermarket intake as a SD intake by removing the maf adapter and keeping the connections on the intake?
Old May 18, 2015 | 12:16 PM
DSMolition's Avatar
They don't have them because almost everyone has a catch can and a aftermarket boost controller by the time they switch to speed density so there is no need.
I use stm's sd intake and just added a brass nipple for the valve cover as I do not need a catch can. I also use a 3port so I don't have it hooked up to the intake for my boost control.
Old Jun 28, 2015 | 03:48 PM
griz's Avatar
So do you even hook up a vacuum line to that port?
Old Jun 29, 2015 | 03:41 AM
AceCampano's Avatar
Get an SD intake that does have port for that vacuum line and call it a day.
ETS Sells SD intakes that have it.
Old Jun 29, 2015 | 05:31 AM
egis's Avatar
If you really want to reuse the lines,yea ditch the maf and leave your existing intake.
Old Jun 29, 2015 | 09:00 AM
griz's Avatar
I don't care one way or the other just wondering if you can leave that port open. I have the ets sd intake and I was under the impression that was a pcv nipple
Old Jun 29, 2015 | 03:15 PM
egis's Avatar
If you talking about 3 port ebc,then you can run the line from the port to intake pipe.or leave it not connected. I didn't connect .
RallySport9
Feb 20, 2016 11:24 PM
ccbremech
27
Sep 9, 2007 02:49 PM
1BlackEvo9
Jun 4, 2006 06:22 PM
o4whtevors
Feb 5, 2005 06:54 PM
