lessons you've learned when working on your Evo
Old Jul 25, 2016 | 06:40 AM
  #31
Rossi_24's Avatar
Every job usually requires you to bust at least one knuckle while trying to loosen Fill and Drain plugs
Old Jul 25, 2016 | 06:44 AM
  #32
lancerrally45's Avatar
This thread is a painful reminder of my upper management. Might as well add a thread, Evo "Best Practices"
Old Jul 25, 2016 | 07:18 AM
  #33
Biggiesacks's Avatar
replace the timing belt tensioner on every belt job. Pulling or dropping the engine/trans by yourself can lead to a punctured a/c condensor. Keep your OEM parts, especially if you live in a state with strict smog laws. The exhaust valve seals tend to leak. Be very aware of how your evo sounds and behaves, if anything sounds or acts different do not ignore it.
Old Jul 25, 2016 | 08:01 AM
  #34
LetsGetThisDone's Avatar
Originally Posted by kaj
1. DON'T WORK WHEN I'M TIRED. i can't tell you how much extra time and money that has caused me.
2. take my time
3. no shortcuts. it's not worth it.
Double, triple, and quadruple check both dowel pins for the trans/block mating surface are in place..... @kaj
Old Jul 25, 2016 | 10:14 AM
  #35
kaj's Avatar
kaj
I can totally line it up myself.
Like I said: working while tired....
LOL
Old Jul 25, 2016 | 10:32 AM
  #36
LOL
I can line it up myself too, by simply installing the dowel pins
Old Jul 25, 2016 | 10:36 AM
  #37
kaj's Avatar
kaj
No dowel pins = weight savings and maximum adjustability.
Old Jul 25, 2016 | 03:17 PM
  #38
Jonno99's Avatar
Kaj and letsget meet again in one of my old threads, it's like mothra v godzilla
Old Jul 25, 2016 | 03:21 PM
  #39
Kaj is the one who left out his dowel pins...
Old Jul 25, 2016 | 03:22 PM
  #40
Don't close your hand around a tool when breaking something loose. Orient yourself so you can push on the tool with an open palm/hand. This prevents you from accidentally punching things when the fastener breaks loose, or the tool slips lol
Old Jul 25, 2016 | 03:28 PM
  #41
This is good advice! Also leverage is your friend. If your cranking on something so hard you cannot control what happens after it breaks, you need to think "Smarter not harder".
Old Jul 25, 2016 | 03:37 PM
  #42
youra6's Avatar
Don't forget the j hook after you check your oil...
Old Jul 25, 2016 | 05:03 PM
  #43
kaj's Avatar
kaj
Your comment is only half true.
Old Jul 27, 2016 | 06:36 AM
  #44
Rossi_24's Avatar
Basically how I started but leverage was tough with a driveway job , I smear a little dirt and grease in it and continue , busted knuckles happen all the time no matter the precaution
Old Jul 27, 2016 | 03:19 PM
  #45
kaj's Avatar
kaj
Jack handles make awesome breaker bars, if you have the room. Or I lock the box end of a large wrench onto the forked end of the one I'm using. If my impact doesn't fit, of course.
The struggle is real LOL
