1st gear whines, paranoid?
Old Jul 6, 2015 | 07:53 PM
booosted's Avatar
Unhappy 1st gear whines, paranoid?
Testing out a car and i hear 1st gear whines, but not in other gears. Signs of death whine creeping in or am i just paranoid.
I've read that its normal if it doesn't whine at higher RPMs but that does not seem normal for me... Any help is appreciated
The Car is 03 Evolution supposedly rebuilt Transmission and t-case
thanks in advance,
Old Jul 7, 2015 | 03:16 AM
roach85's Avatar
Hard to diagnose without seeing/hearing it in person but my 5 speed whines in 1st gear. Never had a whine until I swapped in a 5 speed. Im assuming it is normal, rode in several 5 speed Evos and they all had a faint whine in 1st gear. Not as loud/noticeable as a Honda in reverse but similar sound if you know what I mean.
Old Jul 7, 2015 | 05:54 AM
VWJETTY's Avatar
yeah it's normal. my parent's place is up this hill and i put it in first and cruise up and it whines. a little like a supercharger sound?
Old Jul 7, 2015 | 06:10 AM
Raptord's Avatar
From what I've read death whine is heard at decel in higher gears and higher speeds, not in 1st. And it is normal for first to have a bit of whine.
Old Jul 7, 2015 | 10:57 PM
vicariousthrill's Avatar
I had the same whine in my 03. From what i read its very common to hear it. So i wouldnt worry to much
Old Jul 8, 2015 | 01:14 PM
awhit17's Avatar
First gear is more straight cut, the whine is totally normal
Old Jul 8, 2015 | 10:01 PM
ThisThor's Avatar
Should be normal. Mine has a slight whine also.
Old Jul 8, 2015 | 11:18 PM
LetsGetThisDone's Avatar
Originally Posted by awhit17
First gear is straight cut, the whine is totally normal
It's not straight cut. But it does have a much more mild helical cut to reduce thrust loading on the ball bearing input shaft bearings. Thus, it whines.
First is all the way to the right...
Old Jul 9, 2015 | 06:17 AM
awhit17's Avatar
Edited
Old Jul 9, 2015 | 09:28 AM
Edited
Old Aug 17, 2015 | 03:28 PM
booosted's Avatar
Thank you all for the replies,
Currently excited about getting parts together to make this car even more fun to drive.
Old Aug 17, 2015 | 04:14 PM
nor11384's Avatar
FCOTM Winner
normal
Old Aug 17, 2015 | 04:42 PM
ev00's Avatar
I was paranoid when I first drove my evo too. Totally normal
Old Aug 19, 2015 | 07:05 PM
Ayyrock's Avatar
I was worried that I had the "death whine" because I heard the whine in first gear. Then I searched on here and figured out that it's pretty normal. Mine is a little noisy at times, but as soon as I switch into 2nd gear, it disappears. I'm not entirely sure, but I believe the "death whine" is heard through all the gears and not just one. I've never heard it in person though so correct me if I'm wrong.
Old Sep 2, 2015 | 05:38 AM
itsmeek's Avatar
As stated above, first gear/revers on most manual cars are almost a straight cut/doggear setup. So they will whine.
dtuned
Jun 4, 2009 02:02 PM
WillH19
20
Sep 19, 2008 12:58 PM
Boostin4g63
13
Mar 16, 2008 10:22 PM
onesicklambo
Feb 10, 2006 05:35 PM
tx evo
Jun 1, 2004 04:25 PM
