Evo IX stutter problems, now no start
ok, are you pretty positive it's bad based on this info? I just want to be sure before ordering anything else.. I've already replaced 4 parts its seems with no luck in fixing the issue, and these IAC's aren't cheap. There's a guy selling a throttle body with the IAC in it which I can get for $150, which is the cheapest I'm probably going to get an OEM one for, but I just want to be sure before spending ANY more money.
Where in CO are you? I can take a quick look. I'm in NoCo. I've seen the map sensor and the tps connection loose because the clips were missing. Both caused issues like you described. It could be a bunch of things. Is there a CEL on? Any changes recently? Bad fuel pump can cause this too. I've seen intermittent fuel pumps start a car and when it get's warm it dies.
I'm not saying that. If the car was warm then it will move like your video. If it was dead cold and moved like that then it's bad. There are 120 steps, very small steps.
I don't seem to have a CEL at all, and haven't had any changes. I've been on the same setup for 4 months prior to any of this happening so I'm not really sure what I should check now. Part of me wants to order the IAC valve but I worry that it still won't fix my issue.
I just went and listened to hear if the fuel pump is coming on as people have told me to do, and with the gas cap off while having someone else turn the key on I don't hear ANYTHING. Is it possible that the fuel pump is just that quiet? Or am I looking at a bad fuel pump? Are there better more definitive ways to rule this out as the problem or not? I also cannot hear anything with the back seat off, and the cover for the pump off.
My buddy has a Fuel pump I can get to throw in for $50, so I may just do that tomorrow unless you guys think further testing is required before doing anything.
Thanks for the help so far!
Have or can you check fuel pressure?
SHES RUNNING MOTHER ****ERS!!! Praise jesus and the bacon gods this ***** is going strong now!!
Turns out it was the fuel pump the whole time.. Just threw in a new one and it's running great! I feel so stupid.. I didn't think it could have been the fuel pump because I could smell fuel when I tried to start it these past few weeks. Just goes to show that I need to listen to people better when they tell me what to check lol. Thanks very much for everyone's help!!!!
evl gsr
Apr 20, 2016 02:30 AM
geevolution
Dec 31, 2009 05:31 PM
