Easy way to repair front shock mount - Completely free
The front shock mount on VIII and IX doesn't last quite long. I changed 2 before I figured out what was happening with them. It seems that the bearing wears and get loose, but no. It gets loose in it's cage. The bearing itself won't wear because it does not really heat up or spin quickly.
The whole bearing is hold by a pressed metal ring on it. I'm pretty sure this issue exist on all evos.
To tighten the bearing and get rid of the loose, just tap it with an hammer until there is no loose (tap around to bend it even closer to the bearing) Clean with brake cleaner, regrease and install. Done.
I'm done paying for these.
Good luck
Good luck
maybe this is my problem. I expect it could come on suddenly after some sudden and nasty abuse (massive potholes/street flag bases).
it's a very subtle clunking, it's only obvious when I turn the car off and roll it but it's on both sides, as the car rocks back and forth you hear this slight clunking left and right.
in the picture, we are looking at the underside? we must remove it completely to get the hammer on it?
ILoveAWD
Pacific Northwest
Jun 16, 2012 10:01 AM
Djstorm100
Sep 11, 2009 03:19 PM
