Is this why my car is idling like crap ? ( pics )
Old Apr 11, 2016 | 04:20 PM
DanielM's Avatar
Ok so my car starts like it wants to die again , but if I tap on the gas it comes back to life little by little. Or if I just leave it alone, the rpm will climb slowly . Plus my car revs up between shifts. Anyway I saw this and wanted to see what you guys think .
Attached Thumbnails Is this why my car is idling like crap ? ( pics )-image.jpeg
Old Apr 11, 2016 | 06:00 PM
Bhsj13's Avatar
looks like leaking injector seals?
Old Apr 11, 2016 | 06:20 PM
DanielM's Avatar
Can a car start boggy because of that ?
Old Apr 11, 2016 | 09:03 PM
evillancer06's Avatar
Veteran: Navy
It doesn't really look like much in my opinion. I mean your manifold is obviously building up some crap but I don't think I would just blame the injectors since you have crud going up onto your valve cover. Or at least coming from your valve cover down to your manifold. From the pictures it looks like your injector o'rings are not completely set but it might be a bad angle or something.
Old Apr 12, 2016 | 08:14 AM
LetsGetThisDone's Avatar
Do a boost leak test. If it leaks with 20psi in the system, it certainly leaks when the throttle is closed and there is >15in of vacuum in the manifold..
Old Apr 12, 2016 | 10:25 AM
firmk20's Avatar
the surface area at the top does look rather clean while the rest is dirty, especially where the injector is seated. make sure the o rings on the injectors are good and that the injectors are seating in properly. if there is a leak u would smell or even see it when throttling while looking in that location. it happened to me with a honda i had.
Old Apr 12, 2016 | 11:33 AM
Pal215's Avatar
Almost looks like a leaky valve cover gasket and leaky injector seals. As mentioned earlier, those injector seals can rob you of vacuum.
-pal215
timmeqn
63
May 25, 2015 10:25 AM
wowzers
May 24, 2014 04:42 AM
Cirrusly Evolvd
Dec 21, 2005 06:53 AM
Ralli04Art
Dec 15, 2005 06:24 AM
The Emperor
Aug 5, 2004 01:53 AM
