Evo ecu question
Evo ecu question
I got a evo from theft recovery and it was missing the ecu. Can I just buy another evo 8 ecu and I tr will work or do I have to take it to dealer to do flashing
if its new the dealer can do the flashing they will also set the immobilizer to your key and the correct VIN. if you buy a used one the VIN will be different and depending on which state your in the wont pass the vehicle for inspection. also if its used you need to disable the immobilizer so your key works. next thing you need to worry about is what tune is on that ECU and how it will effect your car safest bet would be to take it to a tuner and have them set everything correctly. hope this helps
Buy the logging/tuning cable, spend 30 minutes reading in the ecuflash subforum and do it all yourself. No need to pay a tuner or dealer. The cable is ~$130 dollars and if you are really on a budget you can find people selling them used in the classifieds on this forum. Getting the ECU working is only the beginning of what you can do with that cable. As an evo owner there is no better bang for your buck mod then that cable and the abilities it grants.
My ECU is locked by Ecutek, i found another one for 80 bucks, now i just need to stop being lazy and order my ecuflash setup, it'll be fun to start to really be able to tune your car
RallySport9
Sep 9, 2013 11:12 AM
03lances
Feb 3, 2010 12:14 AM
