Need help on my boost leak
I need help on my evo 8 i believe its a boost leak, i check my boost gauge its set at 15 psi but it goes all the way to 10 psi passed where it says (vac) on the gauge.
Evoguy!123 (Apr 19, 2016)
in my experience boost gauges go bad pretty often. If you can, verify the gauge is accurate before taking too much apart. On that note though its never a bad idea to visually inspect all the hoses for anything super obvious.
Yes i checked all hoses there all good. Ill check the gauge
[QUOTE=Epyon;11604944]But you shouldn't even make boost at all during idle. It should be in heavy vacuum, My Evo X idles around -20 to -22 psi.[/
Yeah i aint running my car its parked.
So borrow a compressor and do a boost leak test, should be done every year, when you get the pressure up you'll hear air escaping, I found a little broken vacuum pipe around the back on the injectors, never even knew it was there
