oil pressure at WOT?
Old Apr 24, 2016 | 11:41 PM
babaz7's Avatar
hi guys, what should be the ideal oil pressure at WOT? mine shows 73 psi.
is it fine or on the lower side? the block is a stock bottom end and i use shell helix 20-50 weight oil.
currently making 500 whp.
Old Apr 25, 2016 | 01:56 PM
egis's Avatar
I have 03 8 and its around 80 psi at wot. I think you good.
Old Apr 25, 2016 | 02:10 PM
infam0usndn2nv's Avatar
mines is usually around 100 if not more @ wot.... my car makes around 550 and i use brad penn 20w50
Old Apr 25, 2016 | 07:21 PM
Teal2nnr's Avatar
You'll have higher oil pressure if you don't have balance shafts. OP's pressure is fine.
Old Apr 25, 2016 | 07:28 PM
babaz7's Avatar
oh thankyou guys, i was a bit worried, a guy told me that for every 1000 rpm you should have 10 psi of oil pressure. Since my car revs to 8000 it should have been 80 psi, but i guess im fine.
thanks again!
roni4g63
15
Dec 27, 2016 09:08 AM
maknuge
Oct 20, 2015 01:07 PM
Peage
Jan 16, 2015 02:10 PM
hiboost2.0
16
Jan 2, 2014 08:10 AM
jbigelow
14
May 3, 2005 08:46 AM
