03' Evo wont stay running:-(
Old Aug 13, 2016 | 11:48 AM
Dirty Dave's Avatar
Ok guys and or gals!!!!!! ****ing car won't stay running. Was running fine when I parked it at work went to goto lunch and it runs for just a sec and dies. If I feather throttle it runs but misses like hell and can smell raw fuel. I replaced cam shaft sensor and it didn't fix problem. Any info is appreciated.
Old Aug 13, 2016 | 12:36 PM
Biggiesacks's Avatar
Give us some background on the car, millage, maintenance history, mods etc. Also is it throwing any codes? Has it had work done to it recently etc. More info the better
Old Aug 13, 2016 | 02:47 PM
Get your flashlight & look at the fuel injector bank & look for a fuel leak. Dont need an EVO going up in flames
Old Aug 13, 2016 | 03:29 PM
Bhsj13's Avatar
I had same problem a few months back. It was the maf for me. Try swapping with a friend's maf to see. It won't throw a code as it isn't completely failed. Also check the map sensor as well.
Old Aug 13, 2016 | 04:19 PM
Dirty Dave's Avatar
It's a English built, stand alone aem. 193,000 miles:-) I unplugged map and tps it wouldn't fire at all. Plugged back in and dame thing ran for about 40 seconds then puttered out. It has a Magnus intake on it too.
Old Aug 13, 2016 | 06:01 PM
Dirty Dave's Avatar
What is this? MAF, MAP, or TPS
If I unhook battery and leave this unplugged and hook battery back up it runs fine. But then when I plug in is stutters and runs hella rich!!!!
Thank you
Old Aug 13, 2016 | 07:10 PM
06RedRalli's Avatar
That's the idle air control valve.
Old Aug 13, 2016 | 07:31 PM
^^^ Yes, Looks the IAC valve. Stock EVOs are mounted below the TB but yours is not stock but looks like the IAC
Theres a procedure in the manual on how to check it. Ive got it if you need
Old Aug 13, 2016 | 07:53 PM
Dirty Dave's Avatar
Yes please!!!!:-):-). Would that cause it to not idle right and run really rich? Thank you so much
Old Aug 13, 2016 | 08:00 PM
Its kinda wild but here it is:
Old Aug 14, 2016 | 03:23 PM
Dirty Dave's Avatar
Hey so do you think it's safe to drive home. It broke down at work and I live 93 miles away from my work. I drove around block a few times it runs good just idle is about 1,300rpm.
Old Aug 14, 2016 | 03:28 PM
I certainly cant make that call. You noted smelling fuel. Did you find the source.
Might be best to flat bed this beast home
Old Aug 14, 2016 | 06:16 PM
Dirty Dave's Avatar
Yea that was with iac plugged in not letting air by so it was so rich it wouldn't run.
ca18hatch24
Jul 25, 2014 02:28 PM
evo_production
May 14, 2014 10:30 AM
F0RSAKEN
Jun 27, 2011 11:21 AM
mitchroxz
Mar 26, 2010 06:33 AM
03lan-evo
15
Apr 11, 2009 12:36 PM
