Clogged fuel injectors again?
Old Dec 6, 2016 | 10:36 AM
Masterr's Avatar
Question Clogged fuel injectors again?
Hey guys, I have an evo 9 MR and around 10 months ago I had clogged fuel injectors, so I've got them cleaned. Then after 3-4 months of cleaning them I had the same problem, so I bought a new fuel injectors and the problem was solved. And now I'm experiencing the same symptoms of clogged fuel injector. So the question is, what causes the fuel injectors to get clogged? I've checked the ignition coil, spark plugs and they are both fine. So It must be clogged fuel injectors again. I will get them checked and cleaned tomorrow but I need to know why are they getting clogged.
Mod list:
Spollin up cop ignition coil
aem fuel pump
straight pipe exhaust
btw its tuned and runs 98 oct
Old Dec 6, 2016 | 10:49 AM
Ev0ikon's Avatar
Stop getting gas from those places. :}
Old Dec 6, 2016 | 03:34 PM
Bmurray's Avatar
what symptoms are you experiencing?
Old Dec 6, 2016 | 10:13 PM
Masterr's Avatar
Do you think 98 oct is causing the problem? I can switch back to 95 oct because I was using 95 for like 5 months and then I switched to 98 oct.
Old Dec 6, 2016 | 10:18 PM
Masterr's Avatar
Very bad idle, increased fuel consumption, and it cannot reach high RPM on WOT.
Old Dec 6, 2016 | 11:17 PM
Masterr's Avatar
I forgot to mention that engine light is on with P0304 and P0201
bwanner
Jun 14, 2018 07:50 AM
Huge
21
Dec 6, 2011 06:18 AM
EvoAznBoi
Jul 7, 2011 07:02 PM
cupOZnj
Site Feedback / Suggestions
Nov 22, 2002 09:59 AM
Tachyon
Feb 11, 2002 10:41 PM
