wideband in rear o2 spot, where to run cable?
For those running their wideband in the rear O2 sensor location, how/where are are you running the cable for it back to the car?
Are you pulling up the carpet and running it underneath in the same place that the cable for the factory rear o2 is or running it along the bottom of the car somehow?
No real reason not to use the stock wiring points, both work.
I originally used the viii rear location that comes through under the passenger seat, then later added a cat and had to move the sensor forward and I used the Lancer hole by the passengers left foot.
Both work fine.
Both work fine.
just pull on the grommet and it comes out, disconnect the rear 02 from the harness, put in the new winds and sensor from the grommet whole inside the car (harness connector won't fit through the hole)
had to take off the passenger seat and the center consoul/shifter cover
murderedevo256
Jul 7, 2010 10:36 PM
dirty0513
22
Jan 14, 2009 10:37 PM
jmartinez1170
62
Jul 19, 2005 06:31 PM
