Help!! what is this connection
Old Jan 20, 2017 | 09:33 PM
Dmx3alo's Avatar
i was removing the fluid control diff reservoir and found this loose connection underneath can something tell me where it hooks up to on an evo 9
it is coming from a bunch of wires electrically taped together
Old Jan 20, 2017 | 09:44 PM
4b11slayer's Avatar
Hmmmm connector doesnt look familiar but based off location and the manual boost controller, it may be wastegate solenoid wiring.
Old Jan 20, 2017 | 10:45 PM
Dmx3alo's Avatar
So is there a good reason why would the previous owner could have removed it or has it come out but accident? And what component does it plug into
Old Jan 21, 2017 | 06:49 PM
hutch959's Avatar
where is it coming from?
out of the wireing harness?
doesnt look like a oem plug
Old Jan 22, 2017 | 11:31 AM
Dmx3alo's Avatar
It comes out of the wiring harness
Old Jan 22, 2017 | 03:54 PM
hutch959's Avatar
ohh... .yea. its like a single flat pin connector.
doesnt it go up to one of the sensors on the thermostat housing?
Old Jan 28, 2017 | 06:28 AM
Dmx3alo's Avatar
im not sure i will check, thank you
Old Feb 2, 2017 | 07:23 AM
daisaw1219's Avatar
That looks like the Starter Signal wire, but you would know right away since your car will not start with out it.
Old Feb 2, 2017 | 05:34 PM
hutch959's Avatar
if its coming out of the battery harness, then yes... that is what it is.
Old Feb 2, 2017 | 05:57 PM
infam0usndn2nv's Avatar
coolant temp sensor for the gauge.....the sensor is located on the thermostat housing
Old Feb 2, 2017 | 06:00 PM
Cali2MDevo8
Feb 10, 2008 02:04 AM
jasonrp15
Jul 12, 2007 08:16 PM
Max-Q
Aug 2, 2006 09:28 PM
Chamama
Mar 2, 2006 09:09 PM
