Suggestion to make my onw race gas, or what can I do?
Hello guys! Maybe this can be a bored, repeated thread or whatever.
Previosly, I´ve always used VP Q16 for race my Evo. Besides the price (5 gallons cost $200 dollars), there is no gVP in my country anymore. I´m looking alternatives to increase the octane rating of gasoline (our crap gas is around 90 oct). I used Xylene (25%)to remove knock sometimes, but I would like to use a mix of pure ethanol with gas (50/50) but I dont know if tis safe?.
I have some races this saturday and Im thinking to race with a mix of xylene, while I decide what to do. Any suggestion or experience making your own race fuel in your evos?
Remember, we only have 90 oct gas, NO E85, NO VP, NOTHING!
I have acces to xylene, toluene and pure ethanol.
in terms of hardware you will probably need to replace, fuel lines, bigger injectors, and a higher flowing fuel pump although idk how your car is setup so you might be safe with some of these parts
another alternative you could use is water/meth injection(ethanol works just as well as meth same with denatured alcohol) but now you have one more fuel tank to worry about, the pump gas you are using combined with water/meth should give you about the same knock resistance as E85 and give you the added effect of cooling the intake charge, I know this is very popular with Camaro guys who make high HP as its cheaper to convert the car to run water/meth injection than it is to convert to running an ethanol based fuel
Mauricio Evo IV (Jan 25, 2017)
Mauricio Evo IV (Jan 27, 2017)
I don't have much experience with evos but in terms of race gas alternatives your best bet is to retune the car for 100% ethanol, E85 is just 15% pump gas and 85% ethanol and is well known for being poor mans race fuel, just make sure your fuel system is ethanol ready, most cars after 96 are rated for use with ethanol but it doesn't hurt to replace all your fuel lines and pump with ones designed for use with ethanol
edit
OP if you're looking for more power on the cheap look into getting a nitrous kit, I'd suggest a wet kit at the very least so you don't have to worry about adjusting your fuel map for a dry shot since the wet kit sprays both fuel and nitrous and if you want to spray a baby shot(anything less than 100shot) you probably won't even need to pull timing although the rule is for every 75shot you pull 1 degree of timing.
If you want to go that route id suggest checking out LS1Tech's nitrous section, there are some really knowledgeable people there who can help inform you on getting a proper nitrous setup on your car. Idk how much time you're looking to knock off but depending on how big of a shot you're gonna spray you can easily add another 50-200hp(shot number relates to how big of a HP jump you want), I have seen guys run a full second faster on spray vs off spray so it can make a huge difference.
Making your own race gas is easy, I've done it for years.
Adding say 25% xylene or toluene gives a great octane boost, the downside is that it's got a greater SG so runs rich. Your plugs will come out black. Adding a % or methanol will lean it out and at the same time give a bit more octane.
There's no point in doing a retune because it's easier to manipulate the contents of the fuel to match the tune.
Mauricio Evo IV (Jan 30, 2017)
One more think. You said adding methanol to the tank? Maybe a 25%? of a gallon? I have a methanol kit, but you said direct to the tank?
It's for water.
Water only. It doesn't need and doesn't want methanol .
The only place for methanol is in the fuel tank.
As for the actual % to add, that's up to you to experiment with due to other variables. I'm not going to recommend any % that way if and when you blow up the engine, it's not my fault.
More people are starting to get away from water/meth injection due to possible catastrophic engine failures if the injection pump fails, and they do fail. In general, any change in your fueling requires a retune for max performance and to prevent blowing up your engine. Best thing to do is to find a fuel mix that fits your needs and get your car retuned with your chosen fuel.
Mauricio Evo IV (Feb 3, 2017)
If you mix meth with pumpgas in the oem tank your going to kill your lines over time and cause clogs and weird fueling issues. Thats why I run 2 seperate tanks and fuel systems.
Once you have all the components of a secondary fuel system the chances it will fail are similar to a pumpgas failure.
EVO8LTW
Feb 28, 2007 06:29 AM
