Help please evo 8
Old Feb 8, 2017 | 01:20 PM
Mackman's Avatar
Help please evo 8
Evo cranks but dont turn over. Battery is good engine light comes on when the key is on the on position.
Old Feb 8, 2017 | 01:51 PM
Biggiesacks's Avatar
you mean cranks but no start? Have you tried pulling codes?
Old Feb 8, 2017 | 02:00 PM
Mackman's Avatar
Yea it cranks and no..car was running got broken into when i went on vacation.
Old Feb 8, 2017 | 02:05 PM
Did you verify they didn't steal anything critical to the engine running, the ecu for example, or other engine related parts? Did they damage the wiring harness, trying to bypass an alarm for example?
Old Feb 8, 2017 | 04:40 PM
Mackman's Avatar
they took the ecu i replaced it. They didnt take no engine parts..
Old Feb 8, 2017 | 04:51 PM
Did you have the immobilizer reprogrammed / disabled?
Old Feb 8, 2017 | 04:53 PM
Mackman's Avatar
The wires not damage at all..
Old Feb 8, 2017 | 05:03 PM
Yah but you have to have the new ecu encoded to match the immobilizer module in your car or it wont start, or disable the immobilizer in the ECU.
Old Feb 8, 2017 | 05:09 PM
Mackman's Avatar
i live in new york now they dont have shops like that when i was in Colorado springs..i even went to the dealership out here and told them they said whats an ecu...no lie so serious
Old Feb 8, 2017 | 05:11 PM
Well that sucks, the dealership is probably the only one who would be able to look up what your immobilizer code should be by your vin, that is unless you had a backup of your ROM from your old ECU. My suggestion would be to either get with a tuner who can disable the immobilizer and install an alarm ( which you should do anyway after a break in), or buy a Tactrix cable, do some reading and disable it yourself.
Old Feb 8, 2017 | 05:25 PM
Mackman's Avatar
Okay i try tomorrow and ill update you
Old Feb 13, 2017 | 05:37 PM
Evoryder's Avatar
They only took the Ecu...
..strange.
Old Feb 14, 2017 | 05:36 PM
barneyb's Avatar
My Evo 8 starts and runs with a hardware store key. After about 2 seconds it quits. So, maybe something else is wrong.
Old Feb 14, 2017 | 05:44 PM
4b11slayer's Avatar
Have you verified
Fuel with pressure at the rail?
Spark?
It could be possible that its ecu related. Either immob fault or wrong ecu idk. Jist suggestions.
Also if you had evoscan you can scan it for fault codes and if it is a immobilizer fault it should have a code.
Old Feb 15, 2017 | 06:18 AM
Mackman's Avatar
..strange.
no they took the seats front and back also
