Evo GeneralDiscuss any generalized technical Evo related topics that may not fit into the other forums.
Please do not post tech and rumor threads here.
What is this vacuum line coming from the intake manifold and going inside the driver side past the firewall, i cant check where it is going coz ill have to chuck the entire dash.. any idea where it goes?
There is a check valve in that line so your brake booster doesnt see positive pressure so make sure you have it installed and facing the right direction or else you will not have power assisted brakes at all times!
yup got the oem one with the check valve and put it the correct side.
