Coolant Leak Mystery
I've had good luck with T bolts on intercooler piping bc you can really crank them down without stripping out the lil gear but when it comes to coolant lines I've stuck with the OEM clamps and they seem to work fine. Not that I have never had coolant leaks bc lets be real I think I've had a coolant leak from like every line over the years. But the OEM clamps have worked well for me and the leaks seem to step from the rubber lines drying up over the years which is simply the nature of the beast.
Thank you all for your responses, does anyone have the part numbers for the hoses and clamps? I am going to take off the undertray soon and go through all the coolant lines and see if there are any leaks
are there any O rings or anything that are on the thermostat housing that could leak?
There's an o-ring on the thermostat. This is going to seal unless cut or if there is debris under it.
