blow off valve????
While a stock 9/X bov will hold 30psi, it will not do it forever. Mine held 30psi then the spring became weak and it lost its ability to hold that much. Most it would hold without leaking was 26/27. I have since switched to a TiAL QR with a 6psi spring and have not had a single issue at 30psi
what happened with the Cobb? how did that one hold up?
Fixed it for you.
Just because you can't figure it out yourself, it doesn't mean that others can't.
Maybe you should lay off the drugs too.
Then your brain might function a bit better.
Stock BOVs don't leak and never have leaked.
What they do is they start to open at about 1 bar of boost.
like here.
But it's probably best that nobody ever figures it out, then sales of aftermarket low quality products won't be affected.
like here.
