Issues with evo 8. Driving me insane. Please help :(
Old Sep 8, 2017 | 11:56 PM
  #31
Addex's Avatar
Originally Posted by Cartel de santa
Put the stock intaked on myne had same issue
really man?? Did you have all if not most of the symptoms I have? Slow spool and Turbo sounding weak etc?
Old Sep 9, 2017 | 01:50 AM
  #32
Addex's Avatar
OK something strange
as soon as the car warms up the engine has a harsh sound to it. If I blip the throttle the engine vibrates badly. Also a heap of fuel is spraying all over the ground from the exhaust when I rev it😢
think it might be time to sell the car.
Old Sep 9, 2017 | 05:45 PM
  #33
RightSaid fred's Avatar
Soot and water?
Fuel doesn't come out of the exhaust.
Old Sep 9, 2017 | 06:14 PM
  #34
Biggiesacks's Avatar
Go to the hardware store, buy some couplers, and make yourself a proper boost leak tester
Old Sep 9, 2017 | 07:13 PM
  #35
Addex's Avatar
Ill be doing that for sure.
I have made some logs today, although I have no idea what Im looking at.
Short term fuel trim is at - 0.0 to 0.01
Long term is 2.6
Does this mean anything to you guys?
Old Sep 10, 2017 | 09:22 AM
  #36
iD33's Avatar
Do you have a check engine light? What program are you using to data log? Take a screenshot next time. Hell, record a video of all the problems and post it on YouTube then post a link here.
Old Sep 10, 2017 | 01:58 PM
  #37
iLLevo_'s Avatar
New boost control solonoid valve.
New diverter valve.
Old Sep 10, 2017 | 02:06 PM
  #38
iLLevo_'s Avatar
Leaky flange/diverter valve has to go.
My synapse diverter valve started leaking and my boost would do similar things. I replaced it with a Tial valve (make sure it will fit properly). My car ran beautiful after that.
Down the road a month or 2 rain had gotten into my boost controller which happened to be a Perrin electronic solonoid.. the previous owner had the open ports facing upward and water got into it. My car wasn't making proper boost and then eventually completely failed which made the car run at base # of boost. I replaced it with the new Perrin electronic boost controller / solonoid and the car ran better then it had ever been.
A boost leak test would do you right.. listen for air.. or spray a mixture of water/soap around areas you think might be leaking and you might find other leaks. Another common spot that goes over time are the throttle body seals.. listen for air near the TB when boost leak testing too.
Old Sep 10, 2017 | 02:55 PM
  #39
SnowGT's Avatar
Did you test another MAF sensor in the car?... a failed MAF not always throw CEL codes but it can make the engine run worse
Old Sep 11, 2017 | 03:36 AM
  #40
Addex's Avatar
You guys are awesome. OK I noticed a pattern.
once I get to low on fuel my car gets some of its power back. As soon I refill It starts feeling dowy and crap. Like I'm driving with the handbrake up.
also I have a new turbosmsrt bov. Is it recommend I get a trial or synapse bov?
I'm doing a proper boost leak test tomorrow and replacing clamps with t bolts. Also taking a video.
Old Sep 11, 2017 | 12:13 PM
  #41
gsrIXevo's Avatar
Not sure if anybody told you this.. but
1) you may want to see if you can find a stock BOV.. you should be able to use that and get you back to a level you can rule our the old one.
2) with your aftermarket BOV some of them come with different springs.. you may want to check to see if you have the weaker spring installed.
3) manual boost controller... have you triple checked to make sure it is not lose or didn't back out on you.. plus there are ways to check if the spring inside of them has gone to **** ( if you have one that uses that type of construction).
Sorry if this doesn't help but i feel that you need to try and put it back to stock if you are keeping the stock tune vs. putting on all these parts and not knowing what happened. (All those parts and no tune.. doesn't make for a happy evo... too many changes without making sure the car can work correctly...)
Last... (i didnt ready the 2 page thread.. but have you upgraded your injectors and fuel pump? (That needs to be also put out there because you really need a tune if that has been touched on the car. )
nlp187
Jul 8, 2012 10:32 PM
jhanksevo
Aug 22, 2006 01:57 AM
evolution_racer
25
Aug 17, 2006 06:58 PM
r.m.s.
Oct 10, 2005 02:21 PM
TexasRS
23
May 25, 2005 12:52 PM
